Leaks rebuilt engine
The engine was rebuilt last year and has run 3000 km, its this normal leaks? If not whats wrong? The leak comes from the left side of the engine, right side its dry!
Old 02-03-2014, 08:12 AM
Flojo's Avatar
In this case, a look from the top would be more helpful.
get a mirror to look behind the injection setup.
or maybe you get a glimpse through the airduct when removing the rotor.
it could be the back/left side of the engine breather cover seal.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 02-03-2014, 08:27 AM
Straight shooter
Lapkritis's Avatar
Looks like cylinder base gasket leaks and head to cylinder leaks... could also be through bolt o-rings or any number of leaks from above like breathers, rocker shaft seals, valve covers, cam plate seals etc. The wind blows the oil everywhere.
Do you know more about the work that was done and who completed it? I don't see cylinder base gaskets or indicators of Curil T squeezing out... that could contribute to leaks.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 02-03-2014, 08:42 AM
Re torque the heads you'll be fine
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 02-03-2014, 08:54 AM
T77911S's Avatar
just curious, did motormeister do the rebuild?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-03-2014, 09:13 AM
Thanks for all answers! Yes a motormeister did the total rebuild of the engine and he have rebuilt old porsche engines for many years. Does it help to retourqe the heads if that its the problem? Both upper and lower studs are steel studs.
Old 02-03-2014, 12:54 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Oh god.... here it comes.
Gary R.
Old 02-03-2014, 01:01 PM
Hahahhahahaah......
Sorry, that wasn't very nice of me.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 02-03-2014, 01:20 PM
pors1968's Avatar
For 3000klms the oil color is pretty black it look base cylinder leaks and i would check the funny exaust plugs beside header they might leak on down shift that why oil is so black for rebuilt engine.
Old 02-03-2014, 02:35 PM
Reiver
Reiver's Avatar
I'd clean it off completely, then run it in place to identify the actual origins of the leak. Really hard to tell unless that is done.
Good luck....re torqueing the heads properly couldn't hurt anything on a fresh rebuild.
Old 02-03-2014, 02:38 PM
GaryR's Avatar
Considering that re-torque advice came from one of the best engine builders in the US I would follow it.. clean it, re-torque, then see if it still leaks..
Gary R.
Old 02-03-2014, 03:03 PM
