Smoky Mountain Region PCA
Aluminum Oil Sump Plate Safe Jack Point?
My '82 911SC has the oil sump plate without a drain plug. I understand this is a preferred point to place a jack to jack up the rear end of the car. If I change the oil sump plate to an aluminum one with a drain plug, will it still be safe/strong enough to bear the weight when jacking up the car?
I "think" some of the plates are cast aluminum and some are machined billet 6061T6 aluminum. I'd probably go with the machined billet but are the cast ones strong enough? Or, would it be better to find a used steel plate with a drain plug?
Thanks,
John
Old 08-09-2014, 05:33 AM
Regis turd ab user
I have one of the Mainely covers on mine for about 8 years and no issues. I also use a heavy leather glove folded over as a pad between the jack and plate.
Old 08-09-2014, 06:13 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
Better still to use the case seam and cushion your jack with rubber. Nice thick cast aluminum won't be going anywhere.
On the other hand, if you bend the plate it's easy to replace.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 08-11-2014, 10:35 AM
I always jack mine from the sump plate, mine is a '79 SC complete with drain plug, but I don't jack directly on the plate. I always place a greater Pittsburgh area phone book between the jack and the sump plate. When the new one arrives, I throw the old one away and use my spankin new pad.
Old 08-11-2014, 10:40 AM
While preventing metal-to-metal contact, a glove, phonebook or hockey puck doesn't change 1500 lbs. of force on the sump plate or engine case. YMMV.
Sherwood
Old 08-13-2014, 11:28 PM
Bill Douglas's Avatar
I never have and never would jack my SC up by having the jack under the sump. I've seen pics of the factory doing it, I just don't like the idea of the poor little engine mounts lifting up the weight of the back of the car. I've bitten the bullet and bought a scissor lift.
Old 08-14-2014, 01:17 AM
Air Medal or two
afterburn 549's Avatar
Not a good idea. if you have ever had one apart -its just a thin aluminum case.
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 08-14-2014, 06:49 AM
HarryD's Avatar
I know lots of folks lift the rear via the engine but you need to ask your self: Why are you lifting your car with it's most expensive mechanical component?
I lift my car using the jack points on the chassis.
As posted before:
Originally Posted by HarryD View Post
Josh:
Lots of discussion, lots of opinions.
Personally, I have heartburn using the single most expensive to repair component of my car to lift my car.
A search using keywords like lift points, jacking, jack stands will provide overwheming feedback. You can do a search with any of those terms and turn up hundreds of threads.
This thread (Jack Help! (Urgent)) has one of the most definitive postings (thanks Bill Verburg):
Originally Posted by Bill Verburg View Post
X's for lifting O's(and X's for stands), there are others, the Os are almost impossible to get a jack on
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Air Cooled
Craig_D's Avatar
Why not just use the motor? I've jacked mine up many times using the motor, but never on the sump plate. It makes no sense to choose the one thing that is of lighter material and bolted to the stout motor itself, instead of the motor.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 08-14-2014, 06:53 AM
Air Medal or two
Just what if ?
Old 08-14-2014, 07:02 AM
Max Sluiter
Flieger's Avatar
How else are you going to get both wheels off the ground at once? Why not lift the car from the second heaviest component?
Old 08-14-2014, 07:39 AM
HarryD's Avatar
I lift one side with the factory jack point. Place my jack stands as needed. Then lift the other side.
Old 08-14-2014, 08:12 AM
Air Medal or two
Everyone that has a aircooled P car ought to get a little scissor lift of sorts.
Not very expensive, and it allows you to roll around under the car safely in a moments notice.
They go high enough to drop and pull the engine. (about 3.5 to 4 feet is plenty.
simple
Old 08-14-2014, 08:19 AM
Max Sluiter
Flieger's Avatar
To me that seems less stable than lifting once from the middle. And while I jack from there when only lifting one side I have actually heard people say not to lift from the factory points because it puts too much stress in that corner with the weight of the engine hanging off the back. But maybe that is just for Targas.
Anyway, my car survived lifting it from both the engine (twice) and factory jack point.
Old 08-14-2014, 05:57 PM
Max Sluiter
Flieger's Avatar
simple
Cool, you got one to loan me? Is it low enough to clear my front bumper?
Old 08-14-2014, 05:58 PM
Under the radar
Trackrash's Avatar
When I want both rear tires off the ground, I place the jack under the rear engine mount. Then again my motor is magnesium.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-14-2014, 06:18 PM
Max Sluiter
Flieger's Avatar
Mine's mag too. 1974 7R case.
Old 08-14-2014, 06:19 PM
Heck, I’m only 5 not 71!
targa80's Avatar
I use a 2-1/2 ton jack just past the sump on the engine casing and forward of the tranny. I have used this method to remove/install the power plant 6 times successfully. it is a matter of getting the right balance point.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 08-14-2014, 06:35 PM
Air Medal or two
Yes you can drive up on them with a lowered car to Ero Ht EZ . Mine is a tad lower.
Get the air over Hyd kind they use in a tire shop. It lets all 4 wheels hang.
You should be able to get a used one at reasonable rate . I paid 400.00 for mine
Old 08-15-2014, 03:33 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I agree that jacking on the sump plate is a bad idea. Just so there's no confusion, i'm talking about the 1983 and older engines with the removable plate. The 84-up engines have no sump opening, only a drain plug casting, and are OK to jack on even though I still don't like the idea of jacking on the aluminum engine case.
IMO your best bet is to jack it where Gordon (Trackrash) suggests. The challenge is accessibility with the jack head. A stock car with the big muffler, heater tubing and oil scavenge line makes it tough to get clean contact with the engine console. Nonetheless, when you put the jack on the steel engine console you're transferring the lifting force to the engine mount console & crossbar that is connected to the chassis/engine mounts. Lifting from there, the engine is just along for the ride and not necessarily being "stressed" to lift the car.
All that said, people have been jacking on the engine forever. So its proven to be OK. I just don't like the idea of putting the load on the very expensive engine.
One thing worth noting about that nice diagram Harry posted is that I would be very careful in the X'd areas that I point to below. Reason I say these are risky is because you have to make sure you get the stands in the right place. The right place is as far to the rear of the floorpan as possible, where the seam/pinch weld is. If you miss and put them just a bit too far forward, you'll put a HUGE dent in the floorpan.
I've seen a bunch of 911s over the years that have been dented there. Either there's a big mushroom in the floor/carpet or you can see where somebody hammered the pan back down to make it sorta flat again. So don't booger up your floorpan by putting your jack or stands there. Put the stands on the torsion bar housing (the "O" locations just below the risky X) or on the outboard bushing + spring plate tube area where it sticks out of the chassis in the wheel well (green circles)
Kevin L
'86 Carrera "Larry"
Old 08-15-2014, 08:03 AM
Tags
drain plug , jack point , oil sump , plate
