not_sure's Avatar
Talking Compression check
What do I need to do this at home, how much will it cost me and how the heck do I do it?
Tom
Old 09-07-2001, 06:51 AM
Senior Member
Superman's Avatar
Post
You need a compression tester. Remove all spark plugs. screw the tester into a spark plug hole and run the starter for 5 or 10 seconds. Be sure to pull the fuel pump relay or make sure somehow that the system is not delivering fuel.
Read the gauge on the compression tester and go to the next cylinder. The actual testing procedure takes just about 15 minutes. Accessing the spark plugs is harder than the compression test itself.
'83 SC
Old 09-07-2001, 09:47 AM
not_sure's Avatar
Post
Can I pick up a gauge at sears or any other automotive type place?
Old 09-07-2001, 01:34 PM
Steve F's Avatar
Cool
Absoulutly $35at Pep boys,just bought one.May the blue bird of happyness bring you bring you good readings
[This message has been edited by Steve F (edited 09-07-2001).]
Old 09-07-2001, 01:44 PM
Steve F's Avatar
Cool
Absoulutly $35at Pep boys,just bought one.May the blue bird of happyness bring you bring you god readings
1967 912 "in progress"
Now ,with a 2.0 T4 to play with!:d
Old 09-07-2001, 01:46 PM
Steve F's Avatar
Post
Wow! I need to go home!
Old 09-07-2001, 01:47 PM
