Engine update : from 2.2 to 2.4 to 2.7RS - Opinions needed!
Well, anyone has the right to change their mind. While scouting options to get more from my 2.2 - options were 2.4 crank/rods or short-stroke 2.5. After compiling parts that i could have easily - friends and others or already have, one suggested to go for a 2.7RS replica.
Here is what i have so far:
2.7 7R case (studs renewed)
2.7 Nykasil cylinders
2.4/2.7 crank/rods
2.2E top-end w/S-cams (heads will be ported to i36 e35)
Ill need pistons with 9.5:1 ratio.
1) Any pistons suggestions for that set-up?
2) Any potential worries apart freaking out doing this?
3) Also have E-cams, should i use them instead of S?
Many thanks.
PCA Member
2009 Audi A3 2.0 Quattro
1978 911 SC Targa
Old 09-04-2002, 10:52 AM
Chuck Moreland's Avatar
I think Mahle makes these with 90mm 9.5, also JE
Chuck Moreland - elephantracing.com - vonnen.com
Old 09-04-2002, 11:13 AM
Id really like the opinion of Early_s_man on this. Where are you?
PCA Member
1978 911 SC Targa
Old 09-04-2002, 02:45 PM
A Quiet Boom's Avatar
E-cams would be more drivable on the street given their lower powerband but as engine size increases it becomes less of an issue. For example a 2.0 with S cams will be significantly more peaky and have a higher powerband than a 2.7 with S cams. It looks like all out power is what you're after and your willing to give up some streetability to get it. My vote for a 2.7 would have to be S cams, but definately E for anything smaller.
Old 09-04-2002, 05:55 PM
Author of "101 Projects"
Wayne 962's Avatar
Wait 30 days before you do anything - I have a chapter on this with about 60 pages of info and pics!
The 2.7RS motor ran 'S' cams...
I personally don't care for the original RS spec - I think that you need to improve on it by bumping up the compression with some custom-made JE pistons. The original RS motor had low compression (8.5:1)
Stock 2.7 engine with
- S cams
- MFI
- JE 9.5:1 or 10.1 (I know someone with a good set of these new)
Will get you more power than the 2.7RS. I'm pretty sure that you will be able to run the stock RS-spec MFI pump too. The stacks are the same as the 2.4S so they are still around (I might have some). Not sure about the t-bodies off the top of my head - I think they are the same too...
-Wayne
Old 09-04-2002, 08:32 PM
Go over to Rennlist and check out the 2.7RS spec engine being offered for sale. I have it on very good authority that these are race engines and do not perform well under 3500rpm. That pretty much rules out street use. Just my two cents.
Regards,
Clinton
"The greatness of a nation and its moral progress, can be judged by the way its animals are treated." M. Gandhi
1977 911S...sold; 03 F20C; 2009 VW Jetta Sportwagen
Old 09-04-2002, 11:42 PM
CamB's Avatar
I dunno about unstreetable.
I have a 3.2RS (lucky me ) - an S cammed 3.2 short stroke.
It is very civil. Very torquey (especially with 10.3:1 c/r). It does benefit from EFI though.
Basically the size of engine makes up for the peakiness of the cam - I still have plenty of torque.
However, I have only driven a few hundred miles and opn the last drive (to and from the tyre shop) a pair (twin plug) of plugs fouled and I needed a run down the motorway to fix. They may be too cold or I may be forced to get 2x MSD (no CDI at the moment).
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 09-04-2002, 11:53 PM
skinnerd's Avatar
I'm prejudiced, but go with the 2.7RS engine configuration. Hugely streetable even with S cams and incredibly great fun to drive. Mine puts a big grin on my face each and every time. I'm talking about a stock 8.5:1 with S cams, MFI, etc, etc. The great thing about 8.5:1 is that you can use any kind of fuel, even 87 octane. Plant your foot, and she'll do 13.8 sec 1/4 miles at 98 mph (rear wheel dyno of 208hp; closer to 235 at the flywheel). If you need more than that, then go build your race motor.
Just my 2 cents.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 09-05-2002, 12:03 AM
Wayne 962's Avatar
CamB - Apples and oranges - you can't compare the 3.2 to the 2.7...
The 2.7RS is not that peaky - they must have other trick mods. It's not like the very early 2.0S motors - it is a good street engine...
-Wayne
Old 09-05-2002, 12:16 AM
The 2.7RS spec. is a race engine. I didn't mean to steer the debate in a different direction. If this is seriously what you really want then I say go for it.
Regards,
Clinton
Old 09-05-2002, 08:03 AM
Carlo A
Guest
Posts: n/a
I find my 2.7RS motor is perfect for street use.
Old 09-05-2002, 08:24 AM
