Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Servicing CV joints...question...
I have disasembled the CV joints, cleaned them up and ready to pack with grease and put back on the shaft.
one big question...there is a washer that seemes to be curved. All four of them were this way. Logic tells me the curve goes toward the CV joint but I wanted to check before putting it all back together.
thanks!
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 02-10-2014, 03:02 PM
correct. under the joint.
206 637 4071
Old 02-10-2014, 03:05 PM
83 Targa
Old 02-10-2014, 03:46 PM
mikesride's Avatar
Step one....buy new axles
step two...bolt them on
what did I miss?
You guys who step up and do the extra work amaze me..... guess I'm just lazy.....or super efficient!!!!!!!
I've driven alot of crap to get here man!
Old 02-10-2014, 03:51 PM
Black and Blue
Kemo's Avatar
thanks for the answers guys...I have 2 more to clean up before packing and assembling the shafts. the cleaned ones are currently soaking in WD40 zipped up in a sandwich bag
mikesride, i did exactly as you did the last go-around, mostly because I had a ticking sound and it was on a DE/Track car. This car im working on now, is only for the street and the CV joints all seemed to be in good working order, this is really a "while im waiting on engine parts" and "usually neglected maintenance" kinda thing.
Also, back when I did purchase the half-shaft assemblies, it had Ford stamped on the CV joints go figure.
Kemo
Old 02-11-2014, 06:44 AM
pete3799's Avatar
Just so you know the CV picture you posted is assembled wrong.
Your picture
This is correct. Note the orientation of the inner and outer races.
Pete
79 911SC RoW
Old 02-11-2014, 07:26 AM
Black and Blue
Kemo's Avatar
Pete,
thanks for the info...im not quite sure what you mean. could you elaborate a bit? i do know the outter metal part has a grooved ring all the way around. does that mean anything?
for some reason, I thought these parts were all pretty much symetrical.
Kemo
Old 02-11-2014, 07:41 AM
T77911S's Avatar
it took me a few minutes to figure it out.
look at the inner race. there is a wide space then a narrow space then wide and so on between the bearings. same thing on the out race. the wide space on the inner is lined up to the narrow space on the outer.
i would be curious to see how this effects the joint.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-11-2014, 07:49 AM
Black and Blue
Kemo's Avatar
wait..i think i see. so the widest part of the inner race needs to center it self on the smallest "ledge" of the outter race? the way I have mine assembled has the large "ledge" on the inner with the large "ledge" of the outter. so im off by 30 degrees if I keep the outter race stationary and rotate the inner race, either way...
does that sound about right?
Kemo
pete3799's Avatar
Correct. Big to small.
If you try to swivel the joint when it's assembled wrong it will bind up.
Pete
79 911SC RoW
Old 02-11-2014, 07:57 AM
Black and Blue
Kemo's Avatar
Pete, this is great information. thank you so much. I love this site!
Kemo
Old 02-11-2014, 08:01 AM
Black and Blue
Kemo's Avatar
one last question...im assuming the "inbetween" cage is symetrical. But what about the grooved outter ring that goes all the way around the outside of the CV Joint. Does that indicate how it should be installed?
Kemo
Old 02-11-2014, 08:03 AM
disband
juanbenae's Avatar
what did I miss?
why would you piss away money if the CV's & axles are in good shape? i for one have more time than money, and half the joy i derive from my car is the time spent under it. if i was into throwing away money id drop it at a shop, pay to have the new axles installed and write a check. to each his own, but im with kemo and the since of accomplishment to be found with a DIY project. then again im not adverse to greasy hand... YRMV..
the joints can also bind a bit if assembled correctly prior to being greased, don't let that fool you.
Old 02-11-2014, 08:36 AM
