Banned
how to remove front hub dust cap?
In my neverending pursuit of achieving the pillar of infinite awesomeness, I'm sadly again struggling w/ removing the front hub dust cap on my '87... recessed caps w/ threaded center. Tried a search but everything just related to the early caps (easy peasy you lucky bastages)
I'd done this years and years ago w/ a puller, a bolt, and a shiit ton of washers.
Heck, I even FOUND the bolt / washer getup I'd put together from back then - must have been feeling smart that day and kept it that way when I'd finished.
Problem is, I'm sitting there w/ the bolt threaded into the center of the cap, looking at my 3prong puller, and wondering exactly how TF do I contrapt this finagled thing so that it threads the center bolt into the bolt I've threaded into the cap - and then have it pull as it's pushing!?!?? Ouch. Painful even to type.
It started making my head hurt looking at it, so I went inside and here I am
Anyone care to help placate mah ignoramus?
Thanks in advance, as always...
Old 02-11-2014, 09:07 PM
I was where you are last weekend. Researched some interesting improvised techniques on this site. Purchased a 10x1.5 mm threaded bolt 3" long for $2.20. I have a 52mm socket for removing the front axel nut on a Landcruiser. Passed the shaft of the bolt through the big end of the socket (the other end that will attach to a rachet flush against the dust cap) and threaded the bolt it into the dust cap. Used the socket as a slide hammer and voila! My biggest challenge was finding a hex wrench for the axel nut that would work. Then I remembered the P-car tool kit. A little time to think and a forage through the tool box = a cost effective solution.
Old 02-12-2014, 02:57 AM
slide hammer.
206 637 4071
Old 02-12-2014, 05:11 AM
cycling has-been
bkreigsr's Avatar
If you're not worried about saving the cap, you can drill a hole in the side, big enough to insert a 6mm allen wrench into the spindle lock bolt - loosen the bolt, then unscrew the whole hub/rotor assembly and pound out what's left of the cap from the inside.
Bill K
Old 02-12-2014, 05:21 AM
Slippery Slope Expert
Steam Driver's Avatar
Go to the hardware store and get a U-bolt; I forget the size so measure the diameter of the cap groove. install the U-bolt in (over) the groove and tighten it. That will give you something to pry on. Works great for me.
Old 02-12-2014, 05:23 AM
Banned
thanks gents
buddy of mine chimed in with this tip:
1) screw all thread in dust cap
2) place hole in bar/plate over all thread so that it's sticking through
3) align plate or bar to sit on top of 2 or more studs across from each other
4) place washers and nut to hold bar/plate against studs
5) turn nut until cap pops off
Old 02-12-2014, 05:41 AM
I assume you are referring to the dust cap that is pressed on? If so I used another Pelican's suggestion of a pari of LARGE Channel Locks to get a good grip on it, then used a small hammer to tap it back and forth. Nothing seems to happen for a few minutes then you see it start to move and it comes off pretty easy after that.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 02-12-2014, 07:08 AM
OffCamber00's Avatar
I welded a nut to them and use a slide hamer to pop them off.
Mat P
1988 911 Carrera
Old 02-12-2014, 07:29 AM
French Import
zippy_gg's Avatar
I used a hammer and a piece of wood at an oblique; came out without too much of a fight.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-12-2014, 08:09 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Cutting torch
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 02-12-2014, 08:30 AM
this is a 930 folks, cap is recessed in the hub. not sticking out like a normal car. slide hammer with a 10mm stud on the end.
206 637 4071
Old 02-12-2014, 08:44 AM
