Senior Member
Ordered voltage regulator and this is what I got.
I ordered a new voltage regulator from germany and of course I thought it would be original design.
Well it was not. Here is a picture of the regulator, so could you please tell me if i have the wires ok on the paper beneath the regulator. And tell me this will work
Projects: 911 -72T EFI "964-look" "Smoky" 914 -71 1.7 D-JET "Rusty" |
PRO Motorsports
I think the DF (field wire) is supposed to be the blue one. The black is D+ and brown of course is D- (ground).
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Senior Member
Hi Tyson. Our cars are falling into despicable disrepair up here. And autocross is boring now. time to come home.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Senior Member
Hmmh, But but...how about this picture
Zen,
Yes, it appears that regulator should work! The markings on your sheet are correct, as the following excerpt from a '73 schematic shows:
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Senior Member
So I guess the middle in my picture is the ground (D-)..
Well, thanks all
you got it.
PRO Motorsports
Oops! Sorry Z-man. Brain fade. (At least I started my response out with "I think..."
I actually posted that, then realized it was wrong while flying on a Jet from L.A. to Seattle. Doh!!! It's like when someone stops you on the street to ask you for directions and then after they're gone, you realize you gave them the wrong directions. Hey, we've all done it. Right?
