SC to Carrera brake conversion questions
I'm putting an entire Carrera brake system on my SC (for race class reasons), and just installed the rear calipers/rotors, a few things:
On the SC the spring for the pad pins don't have this extra retainer that looks like it should lock into something, am I missing something? http://forums.pelicanparts.com/uploa...1393186163.jpg The SC hard line in the rear comes out of the bottom of the caliper, the Carrera out of the inside at a 45 degree angle. As my hard lines are 35 years old i'll just buy new ones. I bent up the SC's to fit just to keep the system closed.. The SC hard line mount - http://forums.pelicanparts.com/uploa...1393186304.jpg Carrera hard line mount (with temporary SC line mounted)- http://forums.pelicanparts.com/uploa...1393186381.jpg |
Hey Gary,
I want to do this also on my 82SC.. Assume it's just upgrading to Carrera calipers and hubs, and it bolts up to same strut mounts holes? thanks |
I don't see anything in PET about that little clip on the pad spring so unless I hear different i'll order the hard lines tonight.. just odd, it MUST clip to something? I bet I'll just end up clipping it off. :D |
And like everyone else in this thread, I am getting ready to do this too. :)
My question is about the master cylinder. It is the same? |
Guess the front rotors had to be changed anyway! :D http://forums.pelicanparts.com/uploa...1393195475.jpg |
Yep, thanks Cory. I'm just going to Dremel them off as they are useless to me. I ended up buying all the hard lines as the fronts took some persuasion to get off the rubber lines on the struts.
Caliper looks great. Did you send them out to be restored or do it yourself?
+1 As someone else mentioned... dremel the pad clips to get rid of the wear sensor tabs AND install the rear bias valve. It goes in the trunk near the MC. Also, one can use the SC pads as they are the same size/shape as carrera pads without the provision for sensors.
Carrera advantage is in the rotors, bigger heat sink.
I get that part, but I can just toss in the pads I was using in the SC (PFC 97) and go? I just assumed the bigger calipers took bigger pads!
The front calipers are almost exactly the same between the cars. That 'almost' comes in the form of a spacer between the caliper halves that allows for the use of the thicker carrera rotors. So, if you've already found a favorite pad, you can keep using it after the overhaul.
To note, I performed this conversion and the only changes I made. Front and rear Calipers and rotors, and rear hard brake lines from a Carrera. I bought new soft lines, pads, and master cylinder from an SC to be thorough. |
They also use the same 20.6mm m/c You are still going to want to run SRF, as these are still very hard working brakes |
| All times are GMT -8. The time now is 04:38 PM. |
