Devil Dog Mosport's Avatar
Part Question
Someone out there must know this.. !
What is the rod that goes from the transmission to the throttle assembly called? What is its purpose?
Has a loop that fits over an arm on the dvrs side of the trans, and then connects onto the throttle assembly on top of the engine..
thanks
Old 02-26-2014, 03:47 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Linkage Rod Pelican Parts - Product Information: 911-423-043-00-OEM
It connect the horizontal rod from the tunnel through the engine tin to the throttle via a bell crank at the front of the engine. The loop is there so that you can remove it once its disconnected at the top.
Who Will Live... Will See
Old 02-26-2014, 04:12 PM
Ah ha. Okay now it makes sense. Had the engine out and transmission separated and had misplaced the rod.
Thank you
1984 Carerra 3.2L - SP911
PCA, SCCA, NASA, ComSport
Old 02-26-2014, 04:20 PM
I think it's also so that you can manually move the throttle butterfly from the engine bay without pushing all of the various linkage parts up to the gas pedal, which might bind or something from being pushed "backwards". If you sit and "rev the engine" from the engine bay, that loop takes up the motion and keeps the rest of the linkage steady.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 02-27-2014, 07:41 AM
Makes sense.. an unintended benefit to German "over engineering"... Danke schon
Thanks Gents
Old 02-27-2014, 07:55 AM
JJ 911SC's Avatar
Correct.
Old 02-27-2014, 08:35 AM
