Starter Noise?**updated****
So I go out to take an early morning run before work. Its cold out, about 15F but really sunny and beautiful.
After I crank the key I get an awful rattle can sound coming from the starter. Last about 2seconds and then clears up. I ignore it and go for a spin hoping im just sleepy and hearing things. It is not a whirring sound but more like rocks in a can. I get back to the garage and retest, same noise on first few starts then wont do it anymore. So here is what I know: 1. Only happens at startup using the starter 2. Does not happen when I pop the clutch rolling out of the garage. 3. Motor runs and sounds perfect after start. Any ideas? I figure Ill pull the starter tonight and have a look-see.
1976 911S MidYear Fever is alive and well. Last edited by Uncle Enzo; 02-28-2014 at 12:27 PM.. |
Difficult to hear clearly with the exhaust noise, but sounds kind of like my starter did when the solenoid wouldn't pull back the pinion gear on the starter.
The pinion would hang in the ring gear and the engine would continue to spin the starter motor. Take a look at the gear teeth when you pull the starter and check the action of the solenoid. My off the cuff guess. C |
Bench test.
I don't think the gear is shooting out all the way.
1976 911S MidYear Fever is alive and well. |
Be carefull as this will chew your ring gear, best to replace. Mine sounded horrible and would hang up for about two minutes.
72 911 Although it is done at the moment, it will never be finished. |
after deeper review, I found the drive is not retracting. http://www.youtube.com/watch?v=GTEXYaFKWrA
1976 911S MidYear Fever is alive and well. Last edited by Uncle Enzo; 02-27-2014 at 08:52 AM.. |
like you found out, the drive can hang up like cooper said. the cold does not help.
you can pull the starter and rebuild it per my thread. you need to check the teeth on the ring gear on the flywheel
Thanks guys. I checked the teeth on the flywheel and they appear to be ok. A little worse for wear but all in order , much like my own teeth.
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 02-28-2014 at 12:39 PM.. |
Thanks so much. I feel a lot better now. I was crapping my pants all morning.
New high torque stater installed. Holy s@&$ this old gal fires up like a new car. Unreal!
GREAT that you got it fixed.....and better than before!
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
