Broke Porsche Owner
Changing the outer shift coupler seal
Can I change the outer shift coupler seal with the gearbox in place?
I put the engine and trans back in without thinking about the outer seal that is mounted to the back of the shifter floor pan box?
I am not speaking of the shifter seal on the transmission but the seal on the body behind the shifter coupler.
Do you ever wonder why the only thing common in all of your dysfunctional relationships is YOU?
Old 02-27-2014, 05:34 PM
AutoBahned
RWebb's Avatar
yes - remove the shift coupler
Old 02-27-2014, 05:59 PM
Broke Porsche Owner
Thanks!
So you push the seal out from inside the shift coupler box?
Sorry, I removed it but it was a few years ago and I don't remember how it came out (if there was one in there).
Old 02-28-2014, 12:49 PM
Go-Kart Mozart
JAR0023's Avatar
On my 86, yes, both seals are put in place from the inside. My car has a flange that faces inward around hole the shift shaft come through. LIke Webb said, remove the coupler from the set screw side so you don't lose your adjustment. Outer seal slides inside out and down over the snout of the trans and has a fold on the big end that covers the flange. Big end of the accordion seal goes over the big end of the outer seal. I zip tied mine in place.
Tangent - When I bought my car both seals were missing. The trans shift shaft seal had a tiny leak, that ended up in that area at the back of the tunnel. Trans had Swepco in it. Whole inside of the car smelled like Swepco. Charming at first but grows old quickly. Didn't take me long to decide I wanted those seals in place. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 02-28-2014, 01:53 PM
Go-Kart Mozart
JAR0023's Avatar
screen cap of the PET showing orientation. -J
86 Carrera
H. L. Mencken
Old 02-28-2014, 02:14 PM
