Question What would you do (and how would you do it?; window stuff...)
After re-greasing the window motor on my '83SC, I am wondering the best way to reattach the gear cover.
I've got liquid gasket, but the edge of the motor housing is very narrow/thin, and therefore I am worried that some gasket can seep into the gear teeth - not a good thing.
The original gasket is a bit crispy, but looks serviceable with an application of liquid gasket as well.
The other thing is that the cover plate will probably have to be attached with a bit of JB Weld or similar at the round attachment points.
How would you close it up? I don't want to go thru this again (wait, this is from my passenger door, I've got a whole 'nother door to rehab...). Please relate any other experiences in this area, they are welcome as I continue my door rehab...
Thanks, Pelicans!
Old 03-08-2014, 06:57 AM
faverymi's Avatar
I would buy gasket material and cut my own.
I wouldn't used any semi liquid material that could drop and solidify within the gear case.
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 03-08-2014, 07:03 AM
Interesting! Would window weld (comes in a roll, pliable, about the consistency of silly putty) serve as "gasket material"?
My thought exactly on getting stuff in the gear case...
Old 03-08-2014, 07:13 AM
