| gordner |
03-19-2015 12:16 PM |
I neglected to take pics of the spark plug set up itself, but it is painfully simple. I just drilled the corner of the hex of the plug, there is enough room to drill clear through. I then inserted the twisted pair of alumel and chromel wires ( i think i mistakenly typed inconel in my earlier post) and wrapped them such that they were in tight contact with the plug and could not pull free. I need to pull some plugs soon I will take a pic and post it then.
I also drilled my P spark plug tool, so I can just disconnect the wire pair, and feed it through the hole in the plug tool so the wires are clear on install and removal.
