blinker/wiper problem
I recently replaced the battery for my 1986 Porsche Carrera coupe with a smaller optima battery. Now every time I turn on my blinkers the wipers go on... Anyone have any suggestions?http://forums.pelicanparts.com/ultimate/smile.gif
just replaced the battery in my 1986 carrera with a smaller version with a cutofff switch. The mechanic also upgraded my a/c..Well, now every time I use my blinkers the wipers turn on. My wipers work fine. Any suggestions
do you guys have any suggestions?
Are there any other items you may have altered?
Yes, I also upgraded my a/c unit.
Can you explain any electric fuse under the dash ground
What happens when you turn on the wipers?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
When I turn on the wipers they work fine.
It probably does not have anything to do with the battery swap.
It is most likely the switch(s) on the steering column. A very common issue.
Dave 2014 Cayman S (Awesome car!) 1991 911 Carerra (Semi Refined fun) 1986 911 Carrerra (Raw fun) sold 2001 Boxster S (Refined fun) sold |
Can I order the switches, and what are they listed as in a parts catalog.
Do a search here on fixing the wiper/turn signal switch. You could save yourself some money.
Andrew 1987 Carrera Cabriolet 1988 Carrera Coupe (RIP) Gone are the days we stopped to decide where we should go......we just ride. |
Could my problem be in the turner light flasher relay, or do I need a turner signal switch...The relay is relatively inexpensive compared to the signal switch...Has anyone else experienced this problem?
por86, try pulling the flasher relay and see if the issue goes away. If it does chances are that it's the relay. If that has no effect, take the wiper switch out of the circuit and see what happens. Warren
Lorraine 83 SC CAB RoW 2003 C4S coupe 07 BMW R1200RT 76 BMW R90S 76 BMW R60/6 |
I had a similar problem with my old 86 targa. I pulled the steering wheel off and inspected the turn signal switch. I could see that it was broken inside, so I just replaced it. In my case I doubt it could be fixed, perhaps it could have been glued back together, but to me, it was easier to replace the switch, and only have to do it once. Time is money too.
Sounds like a poor ground problem. When a particular circuit has a poor ground, it will "seek" a ground through any "back circuit" way it can. Hard to explain, but it causes weird problems like yours. I had your same symptom with the blinkers and wipers. I spent hours tracing, disconnecting, and metering wires till I located the marginal (floating) ground. As it turned out, I had poor grounding where the bundle of ground wires attach to the body/fender,right next to the battery. I cleaned all the wire connecters in the bundle, and the problem disappeared. Check in Bentley manual for a grounding point diagram, and clean up all the ground points in the front part of the car.
I wouldn't start throwing expensive parts at this problem hoping to fix it, you need to determine that a part is truly defective by troubleshooting before you waste a lot of money!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 03-14-2014 at 07:08 AM.. |
Do the intermittent wipers work? Is the switch in the off position?
Rick 88 Cab |
Did you ever find the cause of this issue? I just started having this issue this morning.
'84 Carrera 911 euro (Guards Red) "Jessica" |
