Doug E's Avatar
Cruising gear ?
Don't know why but I starting thinking about this today while I was out cruising around ...
what gear do you typically use when you are cruising at 55/60 when you are out for a drive?
I tend to leave it in 4th b/c it keeps the revs up around 4000 but am wondering if the tranny perfers 5th b/c it drops the revs down around 3000.
BTW, I am not referring to 55/60 on a highway for extended periods b/c in those cases I am definately am using 5th.
Opinions ?????
Doug
'81 SC Coupe
Old 06-09-2002, 04:57 AM
911 user
Milu's Avatar
Depends on the road, straight and flat: 5th. If just cruising one doesn't need acceleration or torque, just change down when you do.
If it's a more demanding road or more "intense" driving, a lower gear might be more appropriate. The car itself "tells" you what gear. With 911s when I have a doubt about which is the "right" gear I tend to err on the sound of caution and select the lower.
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 06-09-2002, 05:58 AM
Crotchety Old Bastard
RarlyL8's Avatar
You might want to check those numbers. Stock SC 915 gearing is not 4000rpm @ 60mph in 4th gear. More like 3000rpm. That is where I like to keep mine running.
Old 06-09-2002, 05:50 PM
Doug E's Avatar
Thanks - I'll check the numbers next time I have her out.
Doug
'81 SC Coupe
Old 06-09-2002, 05:53 PM
CamB's Avatar
Rarly's right - I have a spreadsheet of 915 gearing and it tells me about 3150 in 4th for 60mph (with 205/55R16 tyres or equivalent diameter). 5th gear will be 2550.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 06-09-2002, 06:04 PM
Bill Douglas's Avatar
If I'm not going to be speeding up of slowing down I guess I just use top. But my favorite cruising is in top gear at about 3,500 to 4,000rpm (or more). Just enough to make the car feel lively.
Old 06-09-2002, 07:17 PM
Senior Member
Superman's Avatar
No way I'd use 5th for speeds under 60. Actually,at fifty I'm dropping to 3rd. I'd agree with Bill. Perfect is about 3800 or more in 5th gear. That's what the car likes. Problem is, that's about 90 mph.
Mocha 1978 911SC. "Coco"
Old 06-09-2002, 09:20 PM
Administrator
Jack Olsen's Avatar
For me, 4000 rpm in 5th is only 79 mph.
Fourth is out of the question. With solid motor mounts, this means very non-relaxing highway cruising. However, the torque is always on tap.
Old 06-09-2002, 09:48 PM
