SoCal911SC's Avatar
First project of 911 ownership HELP
Hello all, new Pelican here in my first month owning an '82 SC. Wheels are getting redone with Al Reed so I had some time to dig into the front suspension. List is as follows:
- turbo tie rods
- A Arm bushings
- sway bar bushings
- ball joints
- rebuilt Bilsteins HD's
Problem is I can't get the dang pin out of the lower shock housing. Also, I've taken off the lower nut but the bolt won't budge. I've soaked them in PB to no avail. Any suggestions? Maybe take a torch to it? Thanks in advance.
Any fellow Inland Empire DIY'ers out there?!
Matt
Old 03-16-2014, 09:01 PM
Cars and Cappuccino
tdw28210's Avatar
Try to heat it. If the torch is too scary try a heat gun first. Let it get real hot before going at it.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 03-17-2014, 06:57 PM
SoCal911SC's Avatar
After beating the s#!t out of it tonight, I think I'll give that a go tomorrow night. Thanks.
Old 03-17-2014, 11:17 PM
pors1968's Avatar
I would drill it instead of heat it.
Old 03-18-2014, 02:32 AM
Flojo's Avatar
as this will be solved only with raw force (aparently), I would cut the pin from the balljoint that is still stuck in the strut, as I guess you will mount new ball joints anway.
this done, you can handle the strut better to place it in a jaw vice to drive out the pin and the nut.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-18-2014, 04:06 AM
pete3799's Avatar
One of these and a BFH
Pete
79 911SC RoW
Old 03-18-2014, 04:33 AM
Retired, finally
SiberianDVM's Avatar
That pin caused me great anguish the first time I tried to remove one, but it does come out.
Use the proper size punch: pin is 7mm so use slightly smaller or the punch will jam. 1/4" is almost perfect.
Use a 2lb short handled hammer.
It also works better if the shock is still mounted to the car, so it doesn't move.
Good luck, and bang away.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 03-18-2014, 06:23 AM
I just bought a mid range air hammer. A few blasts and it drove it right out. Mine was better than the $12 units Harbor freight sells but it was not much. The punch bit cost as much as the hammer. It saved me a lot of frustration and busted knuckles.
Old 03-18-2014, 07:22 AM
awhnry's Avatar
The bolt is just in a bind since the complete suspension has been removed from the car. You may need to do some more disassembly to get a better "look" at the bolt but I dont think that it is frozen.
1987 911 Carrera (cassis red sunroof coupe)
2003 Toyota MR-2 Spyder
2006 Mazda Mazdaspeed 6
1992 Mazda Miata(sunburst yellow garage queen)
2001 Ford Excursion
Old 03-18-2014, 07:36 AM
SoCal911SC's Avatar
Hadn't thought of that. I also like the air hammer idea, but before I go out and buy more tools I think I'll try some localized heat first and hit it with the pin punch again.
I don't quite understand drilling it, since to me it seems that would cause the pin to flair out and further bind in the hole....what size bit do you use to drill it out?
Old 03-18-2014, 08:22 AM
douglas bray's Avatar
You need a bigger hammer and the strut need to be somewhere like a vise to anchor it in place or all the force in the world is just going to dissipate away. And heating will do wonders.
And hey neighbor. I am in Rancho Cucamonga and am going to be doing that same project starting in just a couple hours.
Old 03-18-2014, 08:43 AM
SoCal911SC's Avatar
Thanks Doug, let me know how that goes.
Old 03-18-2014, 08:50 AM
SoCal911SC's Avatar
Finally got it. And the winner was the air hammer!
Ended up slightly stripping one of the threaded pins that holds the shock to the ball joint. Try to avoid that if you can......it's a $19 mistake to replace that bolt.
Old 03-18-2014, 05:51 PM
