1986 911/Targa
Need ECU
Question on 1986 ECU..?
I need an ECU for my 1986 911. My little car just won't start. My mechanic said it is the ECU. I Cannot afford a new one. It was suggested to get a used one.what is the difference between used and rebuilt? Well, I know what it means, but is rebuilt almost like new? Or would I be better off getting a used one?
How long would a rebuilt last appose to a used ECU?. Why is it difficult to locate a used or rebuilt ECU?
There is a local place that can rebuilt what I have for $800.00. According to them it would take about 10 days. Is this the price of rebuilt and the time to take to rebuilt is about 10 days. I just want to be sure I am not being taken in. And would a warranty be offered? The place is called "PORSCHE HAVEN" .
Any feed back.? Thx
Regina:
Old 03-18-2014, 08:16 PM
Chain fence eating turbo
Send your ECU (commonly called a DME here) to "ischmitz" for a diagnosis before plunking down money for a used or rebuilt unit.
Willing to bet your mechanic is guessing the problem at this point.
Old 03-18-2014, 08:50 PM
Hi are you sure it is not the flywheel sensor? I had the same problem..can you have your mechanic swap the Ecu, with a known good one ?
Old 03-18-2014, 08:51 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Our Host does these repairs too or you can contact 911Chips.com
'85 Carrera Targa
PCA/POC
Old 03-19-2014, 12:24 AM
1986 911/Targa
Your right about guessing at this point. Coz he thought it was something else at first, he replaced it, but it wasn't it. Good thing about it, he is not charging me for those parts not even labor. He said not my fault, so it's cool. At this point, what shoud I suggest he should be checking or testing, before he takes it apart? Thanks guys for the feed back.
Regina:
Old 03-19-2014, 03:39 PM
There's really 2 options:
1. Multimeter the values of the various EFI components
2. Oscilloscope (not really an option as it doesn't run)
Pretty much just #1 and what most of us do including your mechanic, swap components until it runs.
Old 03-19-2014, 04:16 PM
DRACO A5OG's Avatar
Better yet, find a 3.2 buddy in your area and ask to check your DME in their car. DO NOT PUT THEIR DME IN YOUR CAR, EVER. that goes for all 3.2's Fellas. The reason, if your car is defective, it could damages the donor's DME unit.
Jim
'85 Carrera Targa
PCA/POC
Old 03-20-2014, 10:30 AM
Regina,
If it's the ECU, Parts Heaven sends it to Fuel Injection Corp in Livermore. It's a nice drive from Hayward and if they'll test it while you wait, you could taste at some of the local wineries! Number is 925-371-6551. Great folks and know their stuff.
Tony
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 03-20-2014, 04:14 PM
Diss Member
Quicksilver's Avatar
Do NOT put a known good DME in a car to test the car's systems. There are failed components that can fry the DME.
The correct procedure is to put the questionable ECU in a known good car. That is a safe test.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-20-2014, 06:43 PM
ASE Master Tech - 35 yrs
larrym's Avatar
I have 2 extras - recently road tested, one is rebuilt, one with extra FRWilk performance chip - but price is almost as much as the rebuild price you are quoted
just get it rebuilt
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 03-21-2014, 06:22 PM
Have you checked the relay ?????????????????????????
I wanted to do 1000000 question marks for emphasis , but gave up .
Old 03-21-2014, 06:36 PM
1986 911/Targa
Thanks for all your input. First this flywheel sensor, I was told that this is part of the clutch? Although I did not mentioned the sensor part. The DME relay, I learned that from here when I first experienced the car won't start. Therefore, this time around, I thought perhaps it's the DME again, so I replaced it. Unfortunately it was not it. The. Thought of going to Parts haven is a good possibility. I would have to ask my mechanic to remove the Electronic Control Unit so I can bring it there. Can Ido that? By the way, what's is the difference bet. The DME RELAY to DME. Fuel.? Or I don't remember . Maybe the problems. That other DME thing?
I miss driving that car, especially now with these beautiful weather.
Well, thanks again guys.
Regina:
Old 03-22-2014, 02:07 AM
DRACO A5OG's Avatar
Hayward? That is northern Cali right? I think there are quite a few Pelicans up that ways.
Our 3.2 DME ( ECU ) is held down by four 10MM nuts ( you can use a deep 10MM socket ratchet to remove it ). The DME Relay is mainly to control the Fuel Pump, it was that little black rectangular relay you swapped.
If you can't do it, have your mechanic remove it and find a 3.2 ( 84-89 911 ) to test that DME (ECU) to make certain it is in fact the DME. If it passes, then you would need to look into the two sensors at the fly wheel, Speed Sensor and Reference Sensor, your wrench should know how to measure the OHMs on them to insure they are within tolerance, if not, you need another wrench.
Jim
'85 Carrera Targa
PCA/POC
Old 03-22-2014, 04:52 PM
1986 911/Targa
Yes, Hayward s in Northern CA. I have changed the DME before and it worked. BTW, when you say "wrench", your talking about my mechanic, correct? I am pretty certain that he has checked the DME. I will let him know your suggestion bout the sensor. But you knw come to think of it, i believe, that is what he replaced. He said there are two and thoses two needs to be repaced. I asked him, if they were both bad. He said, you cannot just replace one, it has to be both. Is this correct? Both sensors have to be replaced? I believe this is the parts he replaced and did. It charge me for it because, he felt that its was his mis- diagnose and I should not have to pay for that. I think thats cool.
When I have issues with the car, I dont have anyone work on it but him. But then again nothing like this hs ever happen to it. There were a couple of major? things happened on the car that he diagnosed and fixed or replaced. Hmmm, what was it?Alternator. Some "Ball joint"? I think.
But where does the ECU located. Is that where the DME is connected to? Thx.
Regina:
Old 03-22-2014, 08:39 PM
DRACO A5OG's Avatar
Sorry, Wrench = Mechanic. Oh poop I was just up there today :-(
The ECU aka DME is underneath the driver side seat. The DME relay is there too, but not the same thing.
If he is a Porsche Mechanic then he should have another 3.2 client, if so, ask him if he can ask his client to come on by and quickly swap your DME (ECU) into his clients car. Please do not worry, your DME will not injure the client's car, If it does not start then we found the culprit.
If so, then send your DME to Steve Wong, 911Chips, he is a master of repair of the DME and can fix you right up. But first let's make sure it is your ECU ( DME ).
Jim
'85 Carrera Targa
PCA/POC
Old 03-24-2014, 08:08 PM
Jim
Measuring just the resistance of each sensor is not enough, one needs to also
measure the voltage of each sensor while the engine is cranking, i.e. a common
error.
Old 03-25-2014, 06:21 AM
gtc gtc is offline
abides.
gtc's Avatar
Send your DME to Ingo or Steve Wong. They will fix you right up.
Graham
1984 Carrera Targa
Old 03-25-2014, 08:02 AM
