Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Early (69) Car, Carrera Brake Calipers...which Master Cylinder?
I've got to replace my master cylinder, which is a stock 69 911 T setup. I thought it would be a good time to upgrade if I had the chance. What's the hot setup for an early car with Carrera brakes?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 03-10-2014, 07:56 PM
For the street, I'd stick with the stock 19mm. For racing I switched to a 23mm master. It makes for a hard pedal with lots of effort required. It works ok with high friction race pads.
-Andy
Old 03-10-2014, 09:08 PM
I would rather be driving
jpnovak's Avatar
stock. The caliper piston sizes are the same diameter and you will have the same braking feel/force.
Old 03-10-2014, 09:20 PM
Rennch on YouTube
rennch's Avatar
Ok...I thought a larger one was supposed to give me a better feel.
Michael O'Neal -
Old 03-14-2014, 09:30 AM
The Carrera system came with a factory proportioning valve inline with the rear brakes. Installation is recommended when converting.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 03-14-2014, 10:37 AM
Bill Verburg's Avatar
To a point, yes. But beyond that point no.
check to see what you have now some '69s had a 20.5mm m/c, very rare but very desirable.
Stock brakes would have been M/M w/ either 19.05 or 20.5mm m/c, the slave /master ratio w/ 20.5 is 35.674 w/ 19.05 it is 41.311 lower is better down to the low 30s beyond is just a lot of work w/ 23.8 it would be 26.467(too low for most people)
Bill Verburg
Old 03-14-2014, 11:23 AM
only if you use Carrera 3.2 rotors and caliper f/r, Since the wider rotors aren't needed in back thesmart thing to do is to use Carrera 3.2 fronts and leave the back alone. W/ that setup you have a very nice f/r bias ratio w/o a p/v.
Bill Verburg
Old 03-14-2014, 11:25 AM
Cory M's Avatar
I have driven Carreras with both the stock and 23mm master cylinders. Both cars had Carrera calipers, same brake pad compound, same tires, and weighed within 100 pounds of each other. This was on the same track in the same day. I preferred the stock master cylinder. The 23mm required a lot more force and provided less feedback before the brakes locked up. I would describe it as a smaller "window of operation" if that makes sense. The difference was significant. For the street I would rather have the immediate braking I felt with the stock master.
Old 03-14-2014, 11:30 AM
Rennch on YouTube
rennch's Avatar
Ok...so I replace it with the stock master. Any thoughts on brake pads? I'm mostly autocrossing this car. I've heard thoughts of sticky brake pads in the *rear*, and stock in the front.
Michael O'Neal -
Old 03-18-2014, 08:54 PM
Rennch on YouTube
rennch's Avatar
OH...and I guess I'm looking for a stock master cylinder now. WTB.
Michael O'Neal -
Max Sluiter
Flieger's Avatar
I like the R4S.
Old 03-18-2014, 08:55 PM
Rennch on YouTube
rennch's Avatar
Flieger, do you like them all the way around? Or just front/just rear?
Michael O'Neal -
Old 03-18-2014, 08:59 PM
Max Sluiter
Flieger's Avatar
I use them all around. It is what Eric Shea recommended, and it is what my mechanic uses on his Time Trial 911.
Old 03-18-2014, 09:25 PM
Rennch on YouTube
rennch's Avatar
Ok, thanks man!
Michael O'Neal -
Old 03-18-2014, 09:57 PM
safe's Avatar
For the street and auto-x I don't think that you can go wrong with stock pads.
For track use I'm dead sold on Performance Friction, brakes good and lasts forever...
Magnus
Old 03-19-2014, 03:59 AM
Cory M's Avatar
Since you are considering Porterfield anyway you should call them up and ask their recommendation. They sell several brands including their own. In the past they have given a nice discount to NASA and POC members.
Old 03-19-2014, 07:52 AM
