Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Smart Racing sway bars
Searched for the smart racing sway bars I've had before, said to now be with Jerry woods, but not seeing anything.
Does anyone know if they are still available anywhere?
Thanks,
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 03-06-2014, 11:27 AM
Hi, Jerry defers to Rich Walton at JWE....
They are available and still market them I believe. good luck
Jerry Woods Enterprises
491 McGlincy Lane
Campbell, CA 95008
408-369-9607
fax 408-369-9741
Old 03-06-2014, 11:42 AM
OffCamber00's Avatar
John,
Call Steve Weiner. I got mine from him in the fall.
Mat P
1988 911 Carrera
Old 03-06-2014, 11:52 AM
Racer
winders's Avatar
I think the Tarett bars are better and I believe a little less expensive.
Old 03-06-2014, 12:53 PM
Why do you think they are better?
Mat P
1988 911 Carrera
Old 03-06-2014, 01:09 PM
Cory M's Avatar
I've got a pair of used Smart bars I'm going to be selling next week after I pull them out of storage and take some pictures. I believe they are 27 front and 31 rear. They have some scratches as you would expect after a few years worth of track use. I may even have a spare arm and bushings to throw in. I'm planning on asking $1100, new they were $1500. If interested send me a PM, but I won't be able to respond until next week.
Old 03-06-2014, 03:08 PM
Racer
winders's Avatar
Mostly it has to do with the sizing of the rod end bearings with the Tarett rod end bearings being larger and stronger. I also prefer the slotted adjuster used on the Tarett rear bar lever arm versus the individual holes used by the Smart racing rear bar lever arm.
Old 03-06-2014, 04:06 PM
Stahlwerks.com
jhelgesen's Avatar
I liked the smart bars vs tarret because they do have the holes vs slots. If the bolt loosens in the slot, you can loose adjustment.
Old 03-06-2014, 04:13 PM
Racer
winders's Avatar
If you tighten them properly, neither product's bolts should loosen. Even so, you should be checking those bolts, along with other critical suspension bolts, regularly anyway. The holes make it more difficult to make adjustments.
Both Tarett and JWE make great products. I prefer the JWE sway bar mounting brackets and I prefer Tarett sway bars.
Old 03-06-2014, 05:45 PM
Walt Fricke's Avatar
The pitch for the Smart Racing system was that the curved arms kept the drop links in a more geometrically consistent location. Or, put another way, reduced the change in effective lever arm length with suspension movement. Something like that.
Aren't the Taretts straight?
Was Craig wrong in making the claims he did for the SRP system?
Me, mine are old Weltmeister on one car, and (H&E? Can't remember, but from the '80s - vertical rectangular arms with holes) on the other. Doesn't seem economic to replace them, though if I were building a car I'd probably spring for something nicer rather than go find cheaper older style systems.
Old 03-07-2014, 11:47 AM
Racer
winders's Avatar
How could it effect any change in effective lever arm length with suspension movement?
Dynamically, the lever arm being curved can't have any effect in regards to suspension movement. Think about it. What matters is the line from the center of the sway bar to the center of the bolt holding the drop link to the lever arm. The lever arm is fixed so the arm could be shaped like an "S" and it wouldn't change what happens as the suspension moves. No matter what, the bolt holding the drop link to the lever arm moves in a perfect arc compared to the center of the sway bar. Curved, straight, or "S" shaped, it can't matter.
Old 03-07-2014, 01:49 PM
175K911's Avatar
H&H Sway bars. Leigh Houseman in Chelmsford MA (hope I spelled his name right). Had his bars on two of my 911s in the past and always felt they were the best value in sway bars ever offered.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 03-08-2014, 06:15 AM
jamesjedi's Avatar
27/31 sways......huge and heavy. Why are they so much bigger? Is that what the spec911 guys run?
Old 03-08-2014, 08:52 AM
Cory M's Avatar
I had heard the same kinematics thing you did and I asked Jerry Woods himself about that years ago when I took his transmission class. He said the curve was actually there to provide more ground clearance, same reason the arms are very thick on the bottom web. He knew low racecars could end up dragging the long arms over curbs so he designed them to be durable there.
Old 03-19-2014, 09:55 AM
Thank you - that makes sense.
Old 03-19-2014, 10:10 PM
All of what is said above is true - I've had both.
For example, the Tarrett bars are easier to adjust (esp rear), but the bolts did come loose from time to time.
I think another difference is that the SRP bars can be had in much larger sizes (up to 31mm). The Tarrett site says their largest size is 22mm.
Old 03-20-2014, 08:25 AM
Not only that, the curve makes adjusting them easier. You can move the link by one or 2 holes by disconnecting one side at a time. The link swings along the curve instead when you are moving it. You don't have to struggle to move both sides together.
-Andy
Old 03-20-2014, 05:12 PM
