Thumbs up Heat exchanger removal tip
Just removed both heat exchangers on 1981SC with 100K+ miles. If you round one of the 13mm nuts, you can use a 1/2" hex socket with a 1/4" ratchet to remove the rounded nut. After heating the nut several times, it came off quite easy even with the small ratchet.
Old 09-09-2001, 08:59 PM
