oil pressure sending unit help
hey guys,
my druck press gauge reading is stuck at 0-0.5 and I'm out of ideas, I suck at electrical troubleshooting, please help.
engine running at idle, wire on sensor gauge shows = 0
engine running at idle, wire not on sensor gauge shows = 5
engine running at idle, wire grounded on the engine gauge shows = 0
tested sender unit itself by placing red lead to the sender's prong and black lead to ground, started car and measured resistance in Ohms. I was told if I got fluctuating readings with changes in rpm, sender is good. if sender is bad it should read infinity. I got fluctuating readings, so I assume my sender is good.
battery reads 12.5v, so I assume my alternator is still good.
I thought maybe the female connector was too loose, so I ran a separate wire connecting the female connection to the sender's prong, started the car and still got a reading of 0.
suggestions anyone?
Old 03-24-2014, 11:09 PM
Information Junky
island911's Avatar
If you take the green/red (iirc) wire off of the Oil Pressure Sensor (just right of the engine fan, 7mm nut) your dash-gauge should peg up to the top. That is, the gauge reads resistance to ground. -if that wire goes directly to ground, the gauge should read zero(ish) and if not connected it should read max.
ps, there's this Oil temp & pressure gauge / sender operation
Old 06-02-2014, 10:16 PM
ROW '78 911 Targa
timmy2's Avatar
The senders have a habit of breaking/ corroding at the threaded brass portion where the nut goes on to secure the terminal stud.
Try using a little bit of solder and a soldering gun on the end of the threaded brass (get it good and hot) and see if it works again.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-02-2014, 10:42 PM
T77911S's Avatar
if the gauge reads 0 with the wire connected and 5 with it removed, the sender is bad, just buy a new one.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-03-2014, 03:15 AM
Tags
druck , gauge , oil , pressure
