Cost to change camshafts
I am planning to change my camshafts out for a different grind on my early 2.4 911 at some point in the foreseeable future. In order to save up for the work involved, can anyone please tell me how much I should expect to pay a mechanic to do this for me? Roughly how many hours of labor are involved? I am guessing the engine will have to be dropped to do this, right? Thanks!
$2000
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Thanks. How many hours labor is that calculated on? Does the engine need to be removed from the car? Thanks.
Make sure your pistons have sufficient valve clearance for the new cams you are contemplating.
![]() I've seen people make an expensive mistake by not making accurate measurements before starting the engine.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Yes, the engine needs to come out, that is the easiest part of the job.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
What is CIS MFI or carb that make diff on price.
Thanks. It is a 2.4S engine with E cams at the moment. The plan will be to put original 911S cams in. The pistons are 2.4S Mahle, so they should have plenty of room for the more aggressive cams/valve lift. Am I right? It's an MFI engine, BTW. Does that make it more expensive? Thanks.
Yes MFI will likely add a few hours to the cost.
I am assuming that you are trying to get more torque and horsepower from your engine, if so are there any limiting restrictions that you have. There are many great advisors here that can help you reach your goals
Fleabit peanut monkey
Not a pro but CIS would be easiest and would probably not need any adjustments at all.
Carbs a little adjustment - $ MFI a little adjustment - $$
1981 911SC Targa |
I would also think you will need a new MFI pump $pace Cam to match the new engine cam. More money.
Trial and error with space cams sounds like you would be wise to invest in the time of an experienced pro, and they ain't that plentiful. Just talking.
1981 911SC Targa |
Be aware that E cams make for a less "peaky" engine than S Cams by giving up a bit of hp at max revs. In fact many like the E engine setup for street during as it does not make you rev as much for power.
What your intent for the change? If you are just driving on the street, you might want to keep things the way they are.
..it's complicated...
Yup. I've made no decisions, at least not yet. My objective is simple: to get my engine running perfectly in all conditions.
In speaking with a factory-trained MFI expert, I learned that MFI systems are very sensitive to matching not only the MFI pump (or just the space cam) to the camshafts -- which I have already done-- but also to matching the intake and cylinder head ports to the camshafts and MFI pump. Everything must be matched to the system as designed. And if I were to match my heads to my camshaft and MFI pump, I'd also have to swap out my stacks and throttle bodies to match the intake ports on the 2.4E heads. In essence, I'd be building a 2.4E engine... So, to have an 2.4E MFI pump with E cams on my engine is great, but it's difficult to perfect the setup when intake and exhaust components are mismatched. He said the factory engineered each system the way they did for a reason, and after a lot of research and trial and error. For me to mismatch components -- to try to somehow improve on the lavish R&D poured in by Porsche -- is a bit naive of me, and just like asking for an engine that won't run perfectly. In sum, I'm thinking that maybe I'm better off returning this engine to all factory-designed 2.4S components. The peaky 2.4S engine is obviously wonderful (according to the market, at least). I'm told that If I want the car to run like. 2.4E, I might as well find myself a complete 2.4E motor and stick it into my chassis. I'm finding it hard to punch holes in that logic... What are your thoughts?
So for starters. You need to determine what you have. Has the car been converted to E spec? Which pump, cams, valves etc ?
Once you know the answer, you will know how to proceed. |
Totally 2.4S with the only exceptions being the E camshafts and 2.4E MFI pump. Unless I can buy into a different logic stream, I'll likely install my original 2.4S cams and 2.4S MFI pump. I'll have to rev the engine higher to find the torque and HP, and get stopped by the cops for racing the engine, but I know the engine will run perfectly, as designed,
