CV Joints in an '85
Can someone let me know if the CV joints need to be replaced or fixed somehow on my car? See the video below:
1985 Porsche 911 CV Joints - YouTube Thanks. |
Under the radar
The play in the transmission flange that you were moving is normal. I couldn't see if there is any play in the joint itself. The end play is also normal. The length of the axle must be allowed to change when the suspension moves up and down.
Grab the axle and try to twist it while holding the CV joint. You should not have any noticeable play in the rotating direction in the CV joint itself. Are you getting clunks or grinding noises when you drive?
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 03-28-2014 at 10:42 PM.. |
Remove the wheel and check the torque on the axle nut. Looks like you have play there.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Everything you have shown is normal play. However , there is no harm in pulling them off for a refresh. It's a messy job but worth the peace of mind.
cycling has-been
...to a whopping 333 ft lbs
![]() (best accomplished with a 3/4" drive) Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Member 911 Anonymous
+1 Normal just replaced mine last year. Did not feel like re-building them, Got new GKN's. I went under a low mileage 3.2 and found the same OEM slop.
One thing, I noticed you do not have CV crimps for the end of the boot. You can zip tie or better yet go to your FLAPS and get some metal ties for extra measure.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
