Driving member
jester911's Avatar
Something is unplugged
I was looking around in the engine bay and found a wire with a connector that was unplugged . I looked around and found the other connector that it mates to. The connector is about a 1/2" in diameter and in the end of the plug is two females and one male prongs and the other plug visa versa. One end of the wire goes through the drivers side wheel well and I havent been able to trace exactly where the other end leads.
I plugged it together and started the car and found no difference.
I am sure with more investigation I can figure out what it is but I thought I might save some time if I asked you guys.
Any clues out there?
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 09-12-2002, 02:28 PM
scottb's Avatar
Pictures?
1984 Targa
Old 09-12-2002, 02:39 PM
O2 sensor?
jason
81 SC
Old 09-12-2002, 02:42 PM
Driving member
jester911's Avatar
Well after further investigation I have found that the plug is to the o2 sensor . I managed to plug it back in (yesterday when I did I must not of had it connected all the way) and now my idle is definitely higher.
The question is should I be plugged in or not and is this the reason she failed smog (co was high just barely) ?
I checked archives but didn't find anything definite.
Jerry
Old 09-13-2002, 01:09 PM
Driving member
jester911's Avatar
anyone ?
bueller?
Jerry
Old 09-14-2002, 03:23 AM
Irrationally exuberant
ChrisBennet's Avatar
Yes, it should be plugged in.
-Chris
Old 09-14-2002, 05:55 AM
I would think that on any computer-controlled car the O2 sensor should be plugged in. The computer uses this device to adjust fuel delivery, etc.
It's not important to be the best, just do your best.
Old 09-14-2002, 06:41 AM
scottb's Avatar
The O2 sensor should be replaced every 60,000 miles or so. If your car has that kind of mileage (or more), it's possible the sensor has gone bad and a PO just decided to unplug it. It's not difficult to replace. Pelican sells the part, and others sell a universal replacement.
1984 Targa
Old 09-14-2002, 07:14 AM
Driving member
jester911's Avatar
Thanks guys for the replys. I figured it should be hooked up.
The only thing I am trying to determine now is whether this will help me on smog inspection. I haven't taken it back yet I am trying to avoid a big mechanics bill just to adjust a screw or a plug. It isn't my daily driver so I have been putting it off.
Besides that I am trying to do more myself as I want to be more self-sufficient when it comes to maintenance issues.
Jerry
Old 09-14-2002, 10:25 AM
it will definitely lower the emissions when it's plugged in. carreras need it in the system. SC's can live without it, except to pass emissions.
206 637 4071
Old 09-14-2002, 12:14 PM
Driving member
jester911's Avatar
Thanks john walker. It was as I suspected. I was hoping you or one of the other mainstays on here would help me out on this.
I think I am ready to take it back and give it another shot on the smog test .
Jerry
Old 09-14-2002, 12:30 PM
