Correct charging voltage?
I am trying to track down a smell that has occurred since installing an AGM battery in my 87. It's not a familiar smell, best described as warm plastic. It's in the frunk. It appears to be an issue on longer drives, i.e. 3-5 hours, the ambient temp was close to 90. Smell with and without the fresh air fans running. I don't see any toasted wiring or burnt fuses.
In an effort to track this down myself I think I've narrowed it to the battery. It's been pretty hot when the smell is most noticeable. Everything works, car starts fine, no weird aberrations that I can tell. I'm seeing voltages at the battery with the car off in the mid 13's. Cold idle 14.98 and warm idle at 14.6/7. I don't see a lot of variation with rpm changes, but I'm doing this with a multimeter in my garage.
So, are these numbers a) normal or b) indicative of a bad voltage regulator or defective battery c) none of the above, in which case any alternative theories are welcome.
Old 04-06-2014, 02:03 PM
"Cold idle 14.98 and warm idle at 14.6/7. "
The 14.98 volts is too high. That means that at the alternator in the rear, the alternator
is putting out 15.5-16.0 volts.
Dave
Old 04-06-2014, 02:10 PM
Did you mean to say mid 12's
Rick
88 Cab
Old 04-06-2014, 03:21 PM
wwest's Avatar
That level of voltage drop alternator to battery will only be present with HIGH charging rate. If you do check and find that to be the case then the VR is a problem.
The battery state of charge rises during charging, accordingly, so does the value of the charging voltage also rises.
The SOC of the battery is what actually limits it terminal voltage so whatever voltage the alternator puts out, within limits, is of no matter.
My computerized home charger stops the charge cycle once the battery terminal voltage reaches, stabilizes just below 15 volts. At that point other than a slight trickle charge current the charger goes off-line and the battery terminal drops to the ~13.55V (2.25 volts/cell) standard for lead/acid batteries
Old 04-06-2014, 03:24 PM
wwest's Avatar
No, a fully charged lead/acid battery with no load will have a terminal voltage of 13.50V.
Old 04-06-2014, 03:26 PM
Could you direct me to the source of that data?
Rick
88 Cab
Old 04-06-2014, 03:33 PM
you do mean 12.5 VDC don't you?
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 04-06-2014, 03:42 PM
I just re-checked the battery and saw 13.10. At this point (and lively discussion) it looks like I can confidently start with the voltage regulator. Hey it will give me an excuse to powder coat the housing and fan, whoopee. This would also explain the acid damage I had previously attributed to constant trickle charge by the PO.
Old 04-06-2014, 05:04 PM
just went through this myself, each lead acid cell puts out 2.1 volts, so 12.5-12.6 should be what you're seeing on a fully charged battery without the car running
Old 04-06-2014, 05:36 PM
aus911's Avatar
For interest, I just checked my car, 75 911 with a 3.2, driven 18 hours ago (5 hour trip) and the battery measures 12.5v..
Cheers
Old 04-06-2014, 06:11 PM
wwest's Avatar
2.25 volts/cell x 6 = 13.5V
LS400 battery, Schumacher WM-6000 charger, automatically drops out of charge mode at 100% charge indication.
100% = 13.34 battery no load terminal voltage, Fluke 75 series DMM
2.15 volts/cell vs 2.25 volts/cell...theory vs practice?
http://www.powerstream.com/SLA.htm
Old 04-06-2014, 10:27 PM
T77911S's Avatar
2.25 is the float voltage of the battey. 2.1v is battery voltage.
Battery Voltage Information
http://www.landiss.com/battery.htm
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-07-2014, 03:34 AM
It doesn't turn off it switches into float mode which is the 13.5 volts you see
Rick
88 Cab
Old 04-07-2014, 07:56 AM
wwest's Avatar
13.34V was the measurement with the charger disconnected.
Same results with lawn tractor battery tested overnight.
Old 04-07-2014, 09:10 AM
Is this with the hi/lo pressure switch?
03 Boxster
Old 04-07-2014, 01:02 PM
wwest's Avatar
Charger in float mode connected to LS400 battery overnight. Read 15.7 volts this AM. Disconnected charger and the battery terminal voltage slowly, minute of so, declined from 15.5 volts to 13.7 volts
Old 04-07-2014, 01:48 PM
Just to save the work of taking out the alternator it might be a good idea to have that battery load tested to see if it came with a bad cell.
Rick
88 Cab
Old 04-08-2014, 12:03 PM
to end the thread, I put a new voltage regulator in yesterday and the numbers appear normal per Waynes book. Thanks for the discussion.
Old 04-12-2014, 07:52 AM
Member 911 Anonymous
DRACO A5OG's Avatar
cool
'85 Carrera Targa
PCA/POC
Old 04-12-2014, 08:41 AM
wwest's Avatar
Wasted effort, COST..??
According to this automotive lead-acid "flooded cell" battery charging systems are not compatible with AGM batteries.
Absorbent Glass Mat (AGM) Battery Information - Battery University.
5th paragraph, last sentence:
"Automotive charging systems..."
Old 04-12-2014, 10:19 AM
