Irrationally exuberant
ChrisBennet's Avatar
Brake Fluid - Valvoline SynPower
I've been using SynPower to flush brakes and clutches because is cheaper than ATE Blue, it's clear and it's readily available at the autoparts store. Before a track event I would replace it with ATE Blue. (The color change lets me be sure I got all the old fluid out.) If you aren't having brake problems with ATE, you might want to give SynPower a try. As an experiment, I tried it at Lime Rock yesterday without any ill effects (944S2w/S4 brakes, Pagid pads, 968 cooling ducts). For comparison, the boiling point of ATE is 536 degrees and SynPower is 513 degrees.
-Chris
Old 09-13-2002, 09:46 AM
John Brandt's Avatar
Agreed, It's good stuff.
I've been using it for several years a the track and never had a problem. At five bucks a quart, it's hard for me to say no.
Old 09-13-2002, 10:21 AM
Bill Verburg's Avatar
You guys may have heard this before but ATE blue is no longer (or soon will be no longer) available.
Bill Verburg
Old 09-13-2002, 01:54 PM
disband
juanbenae's Avatar
is the synpower a DOT 4 or 5?
Old 09-13-2002, 03:31 PM
Paul_Heery's Avatar
Old 09-13-2002, 04:58 PM
