Correct charging voltage?
I am trying to track down a smell that has occurred since installing an AGM battery in my 87. It's not a familiar smell, best described as warm plastic. It's in the frunk. It appears to be an issue on longer drives, i.e. 3-5 hours, the ambient temp was close to 90. Smell with and without the fresh air fans running. I don't see any toasted wiring or burnt fuses.
In an effort to track this down myself I think I've narrowed it to the battery. It's been pretty hot when the smell is most noticeable. Everything works, car starts fine, no weird aberrations that I can tell. I'm seeing voltages at the battery with the car off in the mid 13's. Cold idle 14.98 and warm idle at 14.6/7. I don't see a lot of variation with rpm changes, but I'm doing this with a multimeter in my garage. So, are these numbers a) normal or b) indicative of a bad voltage regulator or defective battery c) none of the above, in which case any alternative theories are welcome. |
"Cold idle 14.98 and warm idle at 14.6/7. "
The 14.98 volts is too high. That means that at the alternator in the rear, the alternator is putting out 15.5-16.0 volts.
Dave |
Did you mean to say mid 12's
Rick 88 Cab |
The battery state of charge rises during charging, accordingly, so does the value of the charging voltage also rises. The SOC of the battery is what actually limits it terminal voltage so whatever voltage the alternator puts out, within limits, is of no matter. My computerized home charger stops the charge cycle once the battery terminal voltage reaches, stabilizes just below 15 volts. At that point other than a slight trickle charge current the charger goes off-line and the battery terminal drops to the ~13.55V (2.25 volts/cell) standard for lead/acid batteries |
Could you direct me to the source of that data?
Rick 88 Cab |
you do mean 12.5 VDC don't you?
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
I just re-checked the battery and saw 13.10. At this point (and lively discussion) it looks like I can confidently start with the voltage regulator. Hey it will give me an excuse to powder coat the housing and fan, whoopee. This would also explain the acid damage I had previously attributed to constant trickle charge by the PO.
For interest, I just checked my car, 75 911 with a 3.2, driven 18 hours ago (5 hour trip) and the battery measures 12.5v..
Cheers |
2.25 volts/cell x 6 = 13.5V
LS400 battery, Schumacher WM-6000 charger, automatically drops out of charge mode at 100% charge indication. 100% = 13.34 battery no load terminal voltage, Fluke 75 series DMM 2.15 volts/cell vs 2.25 volts/cell...theory vs practice? http://www.powerstream.com/SLA.htm Last edited by wwest; 04-06-2014 at 11:11 PM.. |
2.25 is the float voltage of the battey. 2.1v is battery voltage.
Battery Voltage Information http://www.landiss.com/battery.htm
86 930 94kmiles [_ _] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ _] RUNNING: [__] NOT RUNNING:01 suburban 330K:: [_ _] RUNNING: [__] NOT RUNNING:RACE CAR:: sold Last edited by T77911S; 04-07-2014 at 03:42 AM.. |
It doesn't turn off it switches into float mode which is the 13.5 volts you see
Rick 88 Cab |
Is this with the hi/lo pressure switch?
Charger in float mode connected to LS400 battery overnight. Read 15.7 volts this AM. Disconnected charger and the battery terminal voltage slowly, minute of so, declined from 15.5 volts to 13.7 volts
Just to save the work of taking out the alternator it might be a good idea to have that battery load tested to see if it came with a bad cell.
Rick 88 Cab |
to end the thread, I put a new voltage regulator in yesterday and the numbers appear normal per Waynes book. Thanks for the discussion.
Member 911 Anonymous
cool
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
According to this automotive lead-acid "flooded cell" battery charging systems are not compatible with AGM batteries. Absorbent Glass Mat (AGM) Battery Information - Battery University. 5th paragraph, last sentence: "Automotive charging systems..." |
