Hi Guys,
Got a question for you. The engine on my 1965 911 (no bloody T E or S) with a 130hp 2.0 is in desparate need of rebuilding. I managed to find a good set of pistons and cylinders (with rings) from a 2.0 911E. The pistons from the E are the same bore and stroke as the original pistons on my car, BUT has a slightly higher compression ratio. Anyone know if these will work on my car? The price is right, I just need to know if it will work. Thanks. Paul |
Navin Johnson
yes they will work
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Thank you very much!!
