Exclamation Can I use higher compression Pistons & Cylinders on my 2.0?
Hi Guys,
Got a question for you. The engine on my 1965 911 (no bloody T E or S) with a 130hp 2.0 is in desparate need of rebuilding. I managed to find a good set of pistons and cylinders (with rings) from a 2.0 911E. The pistons from the E are the same bore and stroke as the original pistons on my car, BUT has a slightly higher compression ratio. Anyone know if these will work on my car? The price is right, I just need to know if it will work. Thanks.
Paul
Old 09-13-2002, 04:33 PM
Navin Johnson
TimT's Avatar
yes they will work
'69 911 GT-5
'75 914 GT-3
and others
Old 09-13-2002, 04:38 PM
Thank you very much!!
