Bumpy Hard Turn
Wondering if this is normal or signs of a problem in an 86 3.2:
If I am turning the steering wheel all the way to one side and turning the car slowly (as when doing a three-point turn), I feel a strange, but fairly substantial bump or two as the car turns. As I straighten the wheel and continue driving, it goes away.
Any ideas as to what might be causing this? In other words, what will I have to order from Pelican Parts next? :/
Old 04-13-2014, 08:34 PM
T77911S's Avatar
toe
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-14-2014, 02:23 AM
pors1968's Avatar
Check wear on tire .Toe is out .Did you lower your car.
Old 04-14-2014, 03:01 AM
See if the tires rub the inside wheel well.... My left one does ever so slightly for some reason... stock setup too (basically).
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 04-14-2014, 03:16 AM
To a certain extent, what you are describing is normal.
JR
Old 04-14-2014, 03:37 AM
I haven't had it lowered, but it has about 103K miles. The tires are new, so don't have enough wear to tell much of anything. Is this a job for an alignment specialist or can an amateur adjust the toe?
Old 04-14-2014, 07:06 PM
T77911S's Avatar
if you put tires on it, go get it aligned.
i jsut put tires on my 930. i did not think my alignment was bad other than my right rear camber.
turns out he adjusted all 4 corners and it is incredible to drive.
i just went to a tire shop, based on a suggestion because he had the latest machine, plus 40yrs exp. turned out to be a super deal. dont think you have to got to a porsche shop and spend $300.
BTW, i had too much too in causing the same problem you have. felt like my tires were grinding on rocks when iturned it going slow.
RACE CAR:: sold
Old 04-15-2014, 03:22 AM
I'll definitely have it checked. You described what's happening perfectly. Feels exactly like grinding over rocks when turning going slow.
Old 04-15-2014, 06:23 PM
