A little Rust!
Took my car in for a clutch and to have oil leaks fixed while engine is out! New exhaust isn't going to happen like planned!
Front main
Rear Main
Both sides of the Trans need seals
2-3 sensors
Major tune up
Adjust the valves
And a whole new pan has to be put in due to a leaky battery or leaky batteries over the years. Time for an Optima. Oh ya, also has a pinched oil line under the drivers door due to someone not jacking it up right! My Dad was the previous owner and never did much of anything to it besides drive. Lol. They said all in all car is in great shape.
If it's going to be that kind of party, im sticken my dick in the mash potatoes!
Old 04-14-2014, 04:17 PM
Double posted same pic, sorry.
Old 04-14-2014, 04:18 PM
Did you say coolant leak?
Chris
'75 911s Targa
Old 04-14-2014, 04:45 PM
Ya, I did! I guess I'm a little overwhelmed right now! Lol. Oops!
Old 04-14-2014, 05:00 PM
El Duderino
tirwin's Avatar
Just a tip because I just ran into this, but make sure you check your positive and negative battery cables. PO on my car had a battery leak and switched to an Optima Red Top but didn't clean up the mess in the pan. I cleaned it up and treated it with POR-15 a couple of years ago and thought all was good. The cables looked fine so I never thought about it, but recently I was tracking down another problem. I just happened to catch a glimpse of greenish color where the outside insulation of the positive wire butted up against the terminal end. Peeled it back and found that the inside of the positive cable was heavily corroded! I cut it back about and inch and a half to get to clean copper and put on a new terminal end.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-14-2014, 05:15 PM
Hard to tell with that picture but it looks pretty nice. What year?
Chris
'75 911s Targa
Old 04-14-2014, 05:16 PM
87, engine was pulled today. Made a special trip down to see the battle wounds. Has 91k on it, first major service it's had in 15 yrs. Said they should be about 2 weeks, no big deal since it's going to SNOW tonight! Lol. 2 to 3 inches tonight per the wife's forecast, unless she's pulling my leg.
Old 04-14-2014, 05:25 PM
tirwin, will make sure to look at cables! Makes sense. Thanks!
Old 04-14-2014, 05:27 PM
Spey's Avatar
If ya don't mind my asking, what kind of quotes are you getting on pan replacement? Pan in our future soon too
Sent from my XT907
Chris
'73.5 2.7L Sepia brown
Old 04-15-2014, 05:01 PM
andy_uranium's Avatar
Nice car. Weird weather today, so you're right he isn't missing any quality road time.
DD - 2011 VW MK6 GTI - Candy White
Currently seeking a 911 Carrera or SC
Old 04-15-2014, 07:19 PM
Project Addicted
Make sure to replace the fuel lines on the engine.
Looks like that fix won't be too bad up front. Hope it's only on 1 side.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 04-16-2014, 04:09 AM
tobluforu's Avatar
Looks like my car, except a little worse. What amazes me is that it's still driveable with the torsion bar there. I have seen countless pics of this rust, but it seems that the torsion bar support never rips out all the sheet metal???
Old 04-16-2014, 07:09 AM
I was quoted $2000. To replace the pan but turned out to be a little more. After everything was said and done, It turned out to be a tad over 12k! Let's just say this is now a well sorted car!!
Old 06-12-2014, 05:33 PM
tobluforu's Avatar
Wait, did it cost you 12k to have that fixed, or did you get the whole car painted as well?
Old 06-13-2014, 07:01 AM
Rust was around $2500. Had many other things taken care of.
Old 06-13-2014, 06:16 PM
tobluforu's Avatar
That's good, I think some would read this as it cost you 12 g's to have just the pan done.
Old 06-14-2014, 03:13 AM
HarryD's Avatar
Inquiring minds want to know, what was done for $12k?
Old 06-14-2014, 06:55 AM
New Clutch
Basically every seal that can leak oil
Front and rear Trans seals
Major tune up
Adjust valves
Repair rust
Repair crushed oil lines
All new BB exhaust
New Yellow top battery
The list goes on, I should post a pic of the bill!
Old 06-14-2014, 03:19 PM
Old 06-14-2014, 03:20 PM
Old 06-14-2014, 03:21 PM
