US Spec 3.2L Compression Ration
Is 130 to 135 across all 6 cylinders on a 1984' US spec 3.2L an okay compression or is that starting to get on the low side.
Thanks |
It is very low, but should run. Fresh after a rebuild mine was closer to 190.
1986 Porsche 3.2 Compression - YouTube
Ed 1973.5 T |
Reiver
Cold.
Go-Kart Mozart
As a reference point my 150k mile 86 is in the mid 170s. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
Reiver
numbers will be less when cold but imo that's still on the low side...I'd have it done warm/hot and have a leak down done if you are doing a PPI
Yes I think I will do a leak down test on it. Thanks for all the replies.
