Cars and Cappuccino
Strut Brace: Standard vs. Traingulated
Looking at a Rennline front strut brace for my '85 Targa. Already running the Targa body braces (the ones that install in the cabin seat belt points).
Anyone have a strong opinion of using the standard single bar brace between the two strut towers versus the triangulated model? The price difference is not that much, but don't want to waster $50 either. Opinions? And as always, thanks Pelican and my fellow Pelicanites.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
Stahlwerks.com
Triangulated will lock the brace down. Without it, you are pushing one side into the other. Its worth the $50 if you have space in your trunk
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Bye, Bye.
I don't have a reference point for a single bar in a Targa, buy I can say that I am happy with the Rennline triangulated strut brace with the body braces in my Targa. The only negative to the triangulated brace is that you loose some space.
Elvis has left the building. |
and the ability to store your folded top in the frunk. that being said i went with the triangulated brace in my targa.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Bye, Bye.
FYI: I can store a my folded top in the front with the triangulated brace.
It would be great to store an "unfolded" top in the front.
ok, so you have the rennline brace as well. i would love to see a pic of your folded top in there with it. it won't fit in mine.
Bye, Bye.
I will be at the garage later and will post a pic for you nineball.
abides.
Haven't driven my car for what seems like ages, but won't the top fit in there sideways near the latch?
Graham 1984 Carrera Targa |
i can't, or haven't found a way to, get my folded top into the frunk with my 3 point rennline brace. hopefully my eyes are about to be opened
Bye, Bye.
Yes, I can fit mine in sideways. Pic will be coming shortly.
porsher
Have you already converted to mono balls or do you still have the rubber bushings?
The reason why I ask is, most of the movement in the strut comes from the rubber mounting components not body shell flex.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Air Cooled
Here's a thread with some pictures: HERE
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
porsher
If your goal is to look like an RSR go for it. If your goal is to reduce movement of the strut, connecting the sheet metal on one side with the sheet metal on the other, is not the best bang for the buck First priority should be mono balls. That's all.
Air Cooled
My only point is that the factory used rubber mounts, with a welded in strut tower brace, and in some cases the cross bracing, on their RSR race cars. If the factory did rubber with braces for their race car, there must be a reason. Perhaps they found that the chassis either went up/down at the strut top or that the outward deflection of the body had more of an effect than the rubber vs monoball. I totally agree that if the goal is to make the absolute stiffest chassis upfront, it would probably be with monoballs and cross bracing. I'm just also offering up some evidence of factory decisions on the race car. I have no way of knowing why they chose to have a brace and rubber strut mounts (instead of also mono balls).Just some thoughts.. ![]() Cheers, - Craig_D
You can, in a pre brake booster car like my -77.
![]() So back date your brakes!
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
"...pre brake booster car like my -77"??? I thought ALL post-76's were power assisted. Was your brake booster removed when the big motor was installed?
Howard '76 911S '53 Nash (!) '01 Audi TT '82 GPZ-550 |
No, it's a difference between ROW and USA cars in 1977.
porsher
They may spend a lot of money for a small improvement because it's all the regulations will allow...and they feel any gain is worth having. So it could be that the RSR raced under regs that required stock suspension mounting points. Not uncommon. In that case they would be forced to use the rubber bushings even if they thought they were a poor solution. In my experience, measuring camber before and after a strenuous track day. It would change significantly with rubber bushings and very little with mono balls. Single strut brace in both cases. Good luck!
Bye, Bye.
Sorry, got busy and didn't post a pic. I got a PM last night asking for a pic, so here you go
