Tony
POR-15 storage without drying?
Has anyone figured out how to do this? The stuff is expensive, and I seem to only need it a dab or two at a time. But when I open up a quart, and try to reseal it, it dries to as hard as a rock. I even tried pouring it into little paint jars but sure enough it all dried up. Anyone else having this problem?
Tony 22 GT4 04 E46 M3 87 Carrera (sold - craving aircooled again) 12 991 Carrera (sold) |
is it only drying out on top? If so, try storing it upside down and it will remain usable from the open end.
Fleabit peanut monkey
OMG - I feel you pain.
Bought my first quart last year. Used some and had residue on the lip of the quart paint can. That was trashed opening the can up next time. Put it in a big plastic medicine bottle. Have not tried to open it since. Fully subscribed.
1981 911SC Targa |
I was able to reuse a quart several times over a pretty long period by putting a piece of saran wrap in between the lid and can each time. Not my idea, the guy i bought it from recommended it.
It goes a long way. Even if I need lots I only buy the smallest little cans.
I turn it upside down and use a self tapping screw to drill a hole in the can to let it drip out (or dab my brush in it). Then I seal it up again by screwing in the screw. The dried paint seals the screw so no more air will get in. I can easily remove a screw, but I can never remove a dried on top.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
trick (actually 2 screws to make pouring easier with an air bleed), but in the top lid, not bottom. Haven't used it in a couple of years, and just checked last week, it's in great shape, just like new! What ever you do, NEVER pry off the top!! POR15 contains isocyanates and is cured by moisture.The moisture that gets in when you open the can is what cures and hardens the paint!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 04-30-2014 at 07:09 PM.. |
Tony
OK I like the screw idea - do you screw in the screw through the original top? Does it excessively leak out when you turn it upside down?
Like the Saran Wrap idea too ... Keep me coming.
I just buy a 6 pack of the 4oz cans, and use plastic between the lid and can.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
I put my extra POR15 in a plastic container with a snap on lid, like Tupperware. Then stored it in my garage, aka beer refrigerator. That stuff lasted a couple of years stored that way.
Didn't open the can until I had a bunch of baby food jars ready. I filled each one, saran wrap. then shut it. Put them all into the refrigerator. Used up one jar at a time. Each jar allows a few opening and closings before either ran out or it hardened. Just bought another can... but I like the screw idea... maybe one on top and one one lower side so you can just let it pour out as much as you need.
Mine is in my fridge.
Tru6 Restoration & Design |
You might also try spraying argon gas in the container before sealing it up again. Argon is inert and displaces air. You may find it in a wine/spirits shop.
To use, remove both screws (so you have an air bleed) and pour out what you need. Easy peasy!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 04-30-2014 at 07:40 PM.. |
Straight shooter
I don't mean to be a dream smasher... but you know POR-15 is just Wurth paint. Don't believe me? Check under your labels (especially on older cans). Literally just re-labeled over the old.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Here's my very old can of POR15. Got it unopened from another Pelican on the for sale
forum. He said he'd had it on the shelf for many years. By the looks of the can, must have be many, many years. Anyway, this is the can I did the screw trick to three years ago, I used about a quarter of it and the contents are still as liquid as water! ![]()
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Wurth does sell a similar product (probably identical formula) just a lot more expensive. 160z POR $31.00 vs 16oz Wurth $48.00 Guess the German name costs more!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 04-30-2014 at 08:35 PM.. |
Straight shooter
![]() Enjoy!
Or maybe the Wurth paint is just relabeled POR15?
Straight shooter
The Wurth label isn't removable and is on bottom. Same product just different art work on the can here ... others can peel their labels to check as well.
Straight shooter
Check Google search results on this question. It's only news here but known for a long time by the rest of the world. Doesn't detract from the effectiveness of the product but maybe some the mystique.
