1987 Carrera
battery voltage or alternator issue
Hi Guys,
Here is the issue I have been having. I voltage on my car is fluctuating and I'm not sure why. When I take the car for a drive for 10 minutes or so the voltage is fine around 13.75 volts while running. Then I turn off the car and start it up again the runs at 12.00 volts. What's up with that? I have a brand new battery. What do you think is the issue? I'm using one of the devices that you plug into the lighter to get the readings. I got that tip from the previous research here ![]() Thanks! Ace
Ace123 1987 Porsche 911 Coupe |
non-whiner
When you restart it, rev it once to kick the alternator then measure the voltage at idle. The alternator only charges the battery when it needs it and in most cars will not start to charge until the rpms exceed around 1500.
"Too much is just enough." |
1987 Carrera
After the restart, I start driving it and I get up to 4000k rpm or whatever and it is still only at 12 volts. Is that normal?
I can test the what you said and report back if that's different from what I said above.
Where and how are you reading the voltage?
The Cap'n |
12.00 volts seems a bit low but if it always recovers to ~13.75 or above, then you have no worries. |
alternator to the battery (alt - starter - battery), an intermittent alternator, or an intermittent regulator. Also, the alternator light must always come 'on' with the key in the 'run' position and go 'out' once the engine starts.
Dave |
Battery charging voltage is rarely a function of RPM.... That, battery terminal voltage rising with engine RPM, only happens with a more fully discharged battery and/or a heavy electrical load, headlights, heater blower, etc, etc. Last edited by wwest; 04-27-2014 at 09:21 AM.. |
How long, how far, must you drive before the battery voltage begins to climb, reaches 13.75 volts or more?
A good battery should put out just over 14V (13.8-14.1) range, from what I've seen on all my cars. If not then you may have an alternator going out, however please check all your grounds including the transmission ground. I found on my Carrera that my transmission ground was disconnected and my voltage was jumping around everywhere even with a new alternator.
When the car is turned off the batter should have about 12.5-12.6 Volts. If you battery functions as I mentioned above but when turned off it reads less than 12 or slight above but below 12.5 Volts then you may have a dead cell in the batter. I hope it helps, good luck. Best Regards, Determined
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
Assuming you have a new battery (like you said in your OP) you might have an issue with your alternator.
Most likely the brushes are at the end of their life and sometimes it puts out power and sometimes it doesn't. As a result sometimes you see the voltage going to the 13V - 14V area (battery is charging) while at other times you are running off battery power only and you only read 12V. And as others suggested check the GND strap and the connections at the starter, the alternator and battery. Especially, if someone was in there recently. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
I just reread the thread. Testing your voltage through the lighter has got to be one of the WORST possible ways to assess the condition of the charging system. You MUST read the voltage directly at the battery posts, even if it means running wires into the cabin from the battery. The lighter is at the end of a lot of connections and wire of indeterminate condition, and will NOT accurately reflect charging or at rest voltage. It's kinda like the volt meter in a 914, commonly known as "eye candy". Do it right, do it once.
The Cap'n |
ROW '78 911 Targa
1987 Carrera
OK - Here's what I did this afternoon. I tested the voltage at the battery while the car was off and then compared it with the voltage on the cig lighter meter. They were off by about .1 volts. I also checked when the car was running with low revs and parked . Again, it was off by about .1 volts or so. So I think it is a good enough reading. Here are the readings for the test:
Car off: 12.00volts Started car, headlights on/off for about 2 seconds, revved to 2000rpm: 13.75 V Had the car idle for about 5 minutes, backed out of the garage then stopped: 12.00 V Then drove for 10 minutes and the voltage went to 13.75 v then dropped to 12V Then 2 ten minute trips with start and stop. The Voltage was mostly 11.5v then at one point it dropped to 8 to 9 volts and the battery light came on and then went off on the dash board. Then back up to about 10 or 11V. Then I parked it and scratched my head. What do you guys think? Thanks! Ace
Bad alternator (brushes EOL)
I had the same issue and it was definitely my brushes... I have an extra voltage regulator with good brushes if you need one pm me... If you are really worried I would take your alternator to an auto electrical shop and have them test it.. If you pull your voltage regulator out and the brushes are worn down you may need to get the bearings turned.. My unfortunate alternator was in bad shaped and needed to be replaced...
Here is my thread with my situation. Condition of this Alternator? |
Voltage
Had a similar issue; voltage would be fine while driving for a bit, 14.4V, then drop to 12V or so. It turned out to be a bad ground cable from the tranny to the chassis. The cable looked good and metered fine, but the new cable solved the problem. However this was after a new battery, alternator rebuild and testing the tons of other electrical testing $$$. I used the little volt meter plugged into the lighter too. Excellent test tool.
If you can reproduce the situation, use a set of jumper cables to simulate a new ground cable. Connect battery ground to the chassis and engine at different spots to see if it fixes the voltage.
-Rick Central PA 1989 Linen Grey Metallic 944 Automatic (Daughter's first car) 1984 Slate Blue Metallic 911 Cabriolet ROW, 220 WHP, Steve Wong Chip, Fabspeed Muffler, Cat Bypass. 1987 Black 944S - SOLD 1969 Aubergine 911T - SOLD |
^ start there
Clean the grounds, one at the trans, another one actually on the alternator (this means you have to remove the alt) and check the one at the a battery. These are the big ones, many more but I would start there. That being said, it sure sounds like the alternator is tired..... |
I had some similar problems as the poster, and I ended up replacing the voltage regulator which solved the problem.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... Last edited by jwakil; 04-28-2014 at 07:54 AM.. |
