Oil Pressure Sender
Another question for everyone... 1982 SC targa and uncertain on the year of the engine.
Am I missing an oil pressure sender? I see it in some photos but not in others. This is a photo of my engine:
1982 911 Targa, 3.0L ROW with Webers |
Check rear might be there instead of idiot light.
Just looked up my engine numbers: 1980 SC
I don't see anything that looks like an Oil Pressure sender front to back...
ROW '78 911 Targa
Post the serial number and type of the engine. they are in the picture but can't quite make them out.
Vertical: *6303254*
Horizontal: 930/09
ROW '78 911 Targa
Just saw your post on the year.
it appears you are missing the block and sender that are usually there.
ROW '78 911 Targa
Cool, it is a ROW engine with lower compression and larger port heads.
Higher HP and torque as well. ![]() Simon's Porsche 911 SC Site
Thanks! That's a nice detail I was not aware of and makes a little more sense of the dyno sheets I have for the car...
This has been SUPER HELPFUL! I can scratch two things off of my list.
Can you post picture of top rear engine near thermostat.
Yes, I can. Will have to do it when I get home from work. I looked it over pretty closely and didn't see anything that looked like the oil pressure sender.
But.... I am also new to this and could be missing something.
I did set up my 3L with oil pressure sender at rear. because i had 68 wirring was at back the engine and more space for right heat outlet.
Tried installing the new oil pressure sender last night and found that the cam oil line was a bit too long. I cut 3/8 of an inch off of the hard portion of the line that inserts into the oil pressure sender. Everything will now bolt up no problem.
My question is around the cutting ring. I have a new one to install and need to know if they are to be pressed on to the oil line or will the simple act of bolting everything together press the ring onto the oil line?
Best to mark the length carefully and fully tighten in a vice to ensure you have the ferrule fully compressed on the hard line also saves any strain on the case doing it this way.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Another job done thanks to Pelicans!!
1982 911 Targa, 3.0L ROW with Webers Last edited by Ayles; 04-30-2014 at 11:32 PM.. |
The correct line is shorter, but it looks like that'll work.
The Cap'n |
