wannabee wannabee
WIL84911's Avatar
axle cv joint do i need to replace both
Only one side is bad. Thanks
Old 04-27-2014, 04:32 PM
ganun's Avatar
Quick answer is NO.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 04-27-2014, 05:02 PM
wannabee wannabee
WIL84911's Avatar
Thank you. Wallet is smiling!
Old 04-27-2014, 05:10 PM
Concestor0's Avatar
I did the passenger side CV joint approximately 10,000 miles ago and left the other one alone. I took the driver side joint apart to replace the boot and grease recently and noticed some significant wear. Instead of replacing the joint I just swapped it with the other CV joint on the passenger side so the load and future wear are now on the opposite side of the joint. A little like rotating tires.
It wasn't making any noise before replacing the boot but I'm sure it would have soon, we'll see how swapping it works out. There are a few threads that have information on swapping.
Mine is an '86 so I can only replace the inner joint, the outer doesn't seem to wear as fast anyway.
1986 Porsche 911 Coupe
Old 04-27-2014, 05:53 PM
wannabee wannabee
WIL84911's Avatar
Ok nevermind they both look like these. I'm going to replace both whole units so I can go back to driving then examine and see if I can rebuild the old set. Mine were noisy specially the passenger side (and felt loose when wiggled). Another question - do I need 6 gaskets for my 84?
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 04-27-2014, 06:35 PM
