Warning Buzzer Removal
While walking past my parked Targa in the garage last year, the seatbelt buzzer started sounding for no reason at all. Then, just as mysteriously, it stopped. Then it happened again, and didn't stop. So I just popped out the tach and unplugged and removed the buzzer.
Other than the seatbelt warning, did I disable any other features? I have been driving it without the buzzer for about two years now, with no ill affects.
Thanks so much.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 12-16-2010, 09:44 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks so much.
We removed ours upon delivery of the car................
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-16-2010, 09:46 AM
RETIRED
Joe Bob's Avatar
Now give it the Float Test....
2012 ML350 3.0 Turbo Diesel
Old 12-16-2010, 11:44 AM
cattman's Avatar
When the buzzer in my '87 started to develop a mind of it's own, I too, pulled it. But in doing so, it seems I disabled the lights coming on when the doors open. I cleaned the metal connectors on the relay, and reinstalled it, and replaced the door switches, and viola, all working as it should again.
That may be unique to me car, as other's haven't had that issue.
2005 Porsche 911: 997S, supercharged to 530HP
1987 Porsche 911: Concours prep OEM guards red on black
Old 12-16-2010, 12:36 PM
my buzzer has a mind of its own, can someone post a pic or two of where to remove it from?
Old 12-16-2010, 12:56 PM
Model/year please.
1986 911 Targa.
Only in L.A.:
Old 12-16-2010, 02:54 PM
Originally Posted by 86 911 Targa View Post
Model/year please.
1980 930 euro
Old 12-16-2010, 04:45 PM
1980 930 euro
Here is our '86.
Try this.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 12-16-2010, 05:12 PM
Northern Motorhead
wildcat077's Avatar
The first task i did after i brought my car home was to remove the buzzer relay...
I think i removed one of the gauges for easier access.Put some duct tape to seal the connector after you remove the relay.
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 12-16-2010, 06:48 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The actual buzzer itself is on the ignition switch/steering wheel lockset. See #28
If you lay on your back in the driver floor, you can look up under the dash and get a view of it. I think it's held in place with one screw? Just unplug the electrical connector to it. No need to go after the relay? Not sure......
Kevin L
'86 Carrera "Larry"
Old 12-17-2010, 07:26 AM
can anyone help with with a 1980?
i am trying to find this while my dash is out and all my fresh air duct stuff is out..
there is a couple replays there and just dont know which one to pull
Old 05-17-2011, 06:41 PM
svb svb is offline
Absolutely the most brilliant post ever! No need to pull the relay and kill your dome lights. Simply get on the floor and pull #28 in the diagram to silence that annoying buzzer Thank you thank you thank you! My 930 is now quiet once again!
Boxster Spyder
Old 03-12-2012, 08:15 PM
Ok, so doing my best impression of a contortionist I got on my back and looked up under the dash and this is what I saw and I took a picture. I tried to mark the important parts to help give you directional reference but I could not locate anything that looks like an item #28. Can anyone help point me in the right direction?
I have already taken a percocet and beer and will probably be going to the chiropractor tomorrow. Thanks in advance for the help.
Old 07-06-2013, 09:59 AM
Here's what I pulled to stop the buzzing (hoping it was the right thing, but even if it wasn't the buzzing is gone!):
In your picture it's behind the black wire where your "back of car" arrow is pointing.
Old 07-06-2013, 03:47 PM
Elombard's Avatar
ahhhh..I can not wait to unplug this thing tomorrow!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 07-06-2013, 07:04 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep panoz7 got it right. Thanks for the confirmation picture
Kevin L
'86 Carrera "Larry"
Old 07-09-2013, 09:32 AM
yayo_ayala's Avatar
will any other function be affected if you remove the buzzer?
Old 05-01-2014, 01:08 PM
Elombard's Avatar
I have not noticed any other effects since pulling mine last year. Other than a calmer demeaner in myself and I think I stopped smoking and kicking my dog after unplugging the blasted buzzer :-)
Old 05-01-2014, 01:15 PM
Porsche Crest
Just unplugged mine and the interior lights won't work. Any ideas?
13 Boxster
85 Targa-sold
99 Boxster-sold
88 Targa-sold
84 Cab-totaled
Old 05-01-2014, 01:41 PM
yayo_ayala's Avatar
Thanks Elombar, since I bough my Porsche I started smoking... I think I know how to revert that
hhackma, I will take a look today after removing the AC ducts and follow the cabel from the clock to the bglove compartment. I will share my experience hopefully that will work.
Old 05-01-2014, 02:22 PM
