Chain tensioner advice please
The engine of my 1976 2.7 is being completely re-built to original specification currently.
My question is, should I upgrade to hydraulic chain tensioners while I have the opportunity?
Any advice gratefully received
Old 03-03-2013, 10:24 PM
kodioneill's Avatar
Yes most definitely.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-04-2013, 04:40 AM
Eva
911SauCy's Avatar
Without a doubt.
Old 03-04-2013, 05:06 AM
matt gineo's Avatar
Absolutely, my original chain tensioners went on me a few months ago. Fortunately it happened when I was about 50 feet from my driveway doing about 5mph at 1,000 rpm when I heard it go. I immediately shut the engine down and fortunately I got away with only having to replace a few valves and of course switching over to carrera tensioners. It would have been a much different outcome if I had been on the highway!!
1976 911 Targa 2.7 CIS
Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior
1963 356 SC- crashed
1962 356 C- sold
1965- 912- sold- fun but too slow
Old 03-04-2013, 07:43 AM
Local Mad Scientist
Andy911sc's Avatar
I bought rebuild kits and rebuilt my old tensioners with the tensioner locks on them. When I eventually get around to rebuilding the entire engine and sporting it up a bit, I am not sure if I will go with the upgrade hydraulic or the mechanical ones that stromski makes where there is no worries of them collapsing.
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 03-04-2013, 07:50 AM
bassfishman's Avatar
I just upgraded to 930's with collars. Why spend the extra $$$
Old 03-04-2013, 08:49 AM
tharbert's Avatar
Collars can break. Avoid!
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 03-04-2013, 09:45 AM
Never did oil fed. Just used 930's with safety collars for 30 years including racing.
Old 03-04-2013, 01:21 PM
Scott R's Avatar
My engine had a broken collar floating around in the sump, well have of it anyway. The other half was shredded by the chain and ended up in the oil passages and cam spray bar.
These collars should be avoided at all costs.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-04-2013, 01:29 PM
I've been running 930 tensioners for quite a few years without problems, be sure and do the ramps and the spacer mod. I don't have collars but if installed correctly I don't see how they can break.
Blead out and use 90 wt oil too.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 03-04-2013, 04:05 PM
Scott R's Avatar
The little allen screws shear under heat and vibration.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-04-2013, 04:07 PM
SCaircooled
Hello - In the midst of upgrading my tensioners to oil fed. Wondering how to get enough slack in the chain to get the old tensioners off. Is there a way to compress the old tensioners? Maybe I am over looking the obvious. Wayne's books just say remove the 13mm nut and slide them off - but that is not working. Thank you to anyone's advice!
Old 05-02-2014, 08:32 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
My experience also. Collar broke and was in the oil sump along with the screws that were supposed to hold it together. I'd go oil fed. Wait- I went oil fed.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 05-04-2014, 07:10 AM
no slack needed. set the crank at #1 TDC and the cams stay put as you slip the tensioners out. just don't pry the chains or move the cams when they're out.
206 637 4071
Old 05-04-2014, 07:19 AM
the collar bolts need to be tightened evenly so they don't get stressed sideways. check that the gaps on each side are even for best results. uneven tightening can also beak the end of the collar off eventually.
206 637 4071
Old 05-04-2014, 07:24 AM
Porsche told me not to upgrage on my 911sc. Hydraulic tensioners apply higher loads than spring ones that can cause premature chain wear on earlier engines. Using collars disguises failure of the tensioner and are also not recommended. Also, according to Porsche, the new spring tensioner they sell differ in some way to the original figment and aren't expected to fail in service. Also remember that hydraylicones can also fail in service but no one ever mentions that! I am sure there are plenty of owners who will disagree with all of this however. If you want a definitive answer, talk to Porsche directly as they are the only people who will not be just offering an opinion without foundation.
Old 05-04-2014, 11:56 AM
BURN-BROS's Avatar
The wide tensioner arms on the "turbo" and pressure fed tensioners are the upgrade.
Early failures were from narrow non-bushed arms galling on the shaft when hot. When the engine would cool, the chain would have a good amount of slack. Upon start up, the chain would hammer the stuck arm and the arm would hammer the tensioner and fail.
The other tensioner failure is from the o-ring in the reservoir. If maintained, there would be little to no failures.
Pressure fed tensioners cannot be serviced and have about the same failure rate as "turbo" tensioners. Smart racing even offered an aluminum plug for the pressure fed tensioners that limited travel in the event it should fail.
Supertec sells a wide tensioner arm for those who want to upgrade.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 05-04-2014, 12:13 PM
