non-whiner
mreid's Avatar
Engine build suggestions?
I'm pulling together the engine for my 904. I have a solid 78 3.0, a set of twin plug rebuilt SC heads with larger ports and valves, and 964 cams. What size cylinders and piston compression is the best set up for solid street performance and an occasional DE? Oh, the cylinders must be a slip fit as I don't want to machine the case. Thanks all!
"Too much is just enough."
Old 05-04-2014, 04:45 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Remember...as reguarding horsepower...
If a little is good
More is better
And too much is just right!!
So...high compression...twin turbos...nitrous injection...the whole nine yards...no...make that 10 yards!
Also...better talk to your friendly bank manager so he doesn't think you are trying to start a run on the bank.
That should do the trick....LOL
Bob
Bob Hutson
Old 05-04-2014, 05:21 PM
non-whiner
mreid's Avatar
I like how you think, Bob!
Needs a nice torque curve for the street and then vavoom!
Old 05-04-2014, 05:55 PM
