rokemester's Avatar
Originally Posted by Oyagi View Post
Thread bump!
Just updated all my tires oem bulbs with the leds and love them. However, I'm having a helluva time getting the rubber basket around the speedo sitting properly around the gauge when it's pushed back in. Short of cutting into my dash to widen the gauge "hole", any tips? Swapping the bulbs took no time, getting that tach back in and looking with the rubber gasket is turning into a pita.
John
Try coating the gasket with some Armoral or similar rubber conditioner. It may help. That's what I needed to do to get everything to snug up and align.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 11-15-2016, 04:22 PM
Driver, not Mechanic
Interior cleaner is what I used. Also don't leave them in an odd shape too long. They will stretch.
Old 11-15-2016, 04:26 PM
Always learning something
Oyagi's Avatar
LED Gauge Tutorial
I ended up using foaming hand soap and got the gasket back in. What a pain. Now my interior smells like Bath and Body Works Beach Day scent
1987 930 Guards Red
2004 Acura NSX Supercharged
2020 Macan S
Old 11-15-2016, 08:00 PM
Great tutorial and exactly the way I did it. Here are mine:
Old 11-21-2016, 08:02 PM
Just found this thread. Looking forward to doing this because I just got an '87 Targa and the gauge illumination at night really sucks. Thanks.
John Meggers
Naples, FL
1987 Carrera Targa
SCCA ITC Datsun 510 (sold)
1980 930 Turbo (sold)
Old 11-01-2020, 10:30 AM
Just adding my $0.02 to this thread. The positive connection on the bulb is a little wire with a small connector pushed through a PCB board. If tension on the positive wire is released, it's possible for the wire to bend to the left or right in the connector which will cause it to contact the side wall (ground). You'll end up with a bad short that will cause problems.
Just make sure that the positive wire is properly seated in the holder and that the bulb is properly seated when installed. Worth a double check to avoid issues..
Old 11-01-2020, 03:42 PM
sky1jord's Avatar
I posted this sometime before, but i see the subject coming up again.
So, this tool, available wherever paint is sold
https://www.thepaintstore.com/Hyde-Tools-Paint-Can-Bottle-Openers-2-Pack-p/46445.htm?1=1&CartID=0
will help pull out your gauges lickety split, no brooms required. It's also helpful in opening paint cans.
Rubbing some dish or hand soapy water on the rubber gauge surrounds will allow you to slide everything back together real slick without tears or bends, and soap won't hurt the rubber.
Cheers
1958 356A - Sold to a rust collector
1978 924 - sold to a sewing machine repairman
1984 944 - meticulously maintained but everything except the drivetrain self-destroyed. Used in trade for my wife's MB
1988 Carrera 3.2 Targa - purchased in 1992 and still thriving. Boy, do I love this car
Old 11-01-2020, 08:21 PM
