Chain tensioners done?
Kind of new to the board and have just been lurking 'til now. Love the board.
I have an 83SC Targa. I bought 19 months ago at 72k and it now has 91k. I did not know about PPI's and such when I bought so just went on my knowledge and fortunately got lucky with a great car. The one thing I don't know is how to tell if the chain tensioners have been upgraded or not. Is there a simple way to tell without tearing it apart?
With it hitting 90k I am starting to worry a little because I keep reading about how bad it is if they go. I have downloaded the threads that discuss it and tell how to do it but they never mention how to tell if it was done. Help!!
Old 09-19-2002, 12:03 PM
jkeyzer's Avatar
If the tensioners have been upgraded to the carerra oil-fed type, there will be brass colored oil lines running down the timing chain covers. These lines terminate in two "bolts" which screw directly into the front of the covers.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 09-19-2002, 12:07 PM
MBAtarga's Avatar
Courtesy of the Technical article on the Tensioner Update located on this website:
Here is a picture of the Left side cover with the brass oil line.
Here is a picture of the Right side cover with the brass oil line.
Mark
'83 SC Targa - since 5/5/2001
Old 09-19-2002, 12:23 PM
Thanks to both of you. I will check it tonight.
Ladd
Old 09-19-2002, 12:34 PM
Irrationally exuberant
ChrisBennet's Avatar
The engine is incredibly clean!
-Chris
Old 09-19-2002, 01:35 PM
