Alternator warning light.....
Hello all:
recently the alternator warning light on my 79SC stays lit for sometimes upto 10 secs on a cold startup, ie. only in the morning, after that all day it is OK, goes out right after start..
Iwill check the v-belt to make sure it is tensioned properly, but other than that what are some symptons for an alternator or voltage regulator getting ready to bite the dust ???
[or is this fairly normal on cold startup, now that it gets cooler at night]....
thanks for any help....
Old 09-17-2002, 04:14 AM
MBAtarga's Avatar
I didn't have any alt warning light symptoms, but I did witness periodically:
- tach "bouncing" wildly
- headlights flickering from dim/bright/dim, moreso after engine was warmed up
Get a voltmeter reading - I used the cigarette lighter jack and witnessed voltage surges beyond 15V.
I had the alternator rebuilt and replaced the regulator to solve my problems (well, the problems above anyway.) I still have others
Mark
'83 SC Targa - since 5/5/2001
Old 09-17-2002, 07:13 AM
Sean Hamilton's Avatar
Bill
Originally posted by bill mateer
......alternator warning light on my 79SC stays lit for sometimes upto 10 secs on a cold startup.........
Have got Wayne's 101 book - in there he explains several warning light symptoms and the diagnosis for each.
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 09-17-2002, 08:18 AM
Senior Member
Jdub's Avatar
You might try cleaning your ground at the battery. That's the cheap "fix." If that makes not difference, use the Search function to determine how to hook a voltmeter to the battery and load the car to check for voltage output.
Alternator AND Early_S_Man will get you great advice.
John
'78 Targa in Minerva Blue
Old 09-17-2002, 11:03 AM
Ove Ove is offline
911 driver
Ove's Avatar
Bill,
Have a look at this thread:
Flickering alternator light
Ove
'77 911S targa
Old 09-19-2002, 02:15 PM
