Banned
Originally Posted by Dave Colangelo View Post
Less Gears = Less shifting = Less time off power and in racing its really all about being on the power as much as you can, isn't it?....
And why overcomplicate something that works just fine....
Regards
Dave
Well said, Dave. I've done a lot of racing in my time, and one of the main goals on track is to shift as little as possible.
Old 05-08-2014, 08:55 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by al lkosmal View Post
I'm assuming that they didn't want to confuse you with too many gears to choose........ while you were spinning off the road....as the boost kicked in...............
LOL. Drove an 89 one time in anger. It has ten gears. Five off boost, five on boost. I would have done better with a two gear box.
I was real scared. Owner and I swapped cars. He smoked me in the twisties driving my 81. He tracks his other Porsche though, so way more skill.
You are not officially a numbnutzzz as Ronnie says unless you drive real fast like you have the skill when you don't. But, then, that would be most of us street only guys, even in the NA 911's.
1981 911SC Targa
Old 05-08-2014, 09:04 AM
gearhead
Java dog pretty much nails it. The chassis was homologated, so they had to fit the gearbox in that space. It was done on the fly after 915's in the first 930 racecars started failing.
To this day the 930/962 gearsets are the widest gears Porsche ever made. Tallest I have ever seen is a .61. Not that much taller than the stock gear, but talk enough to break 220mph at LeMans with the higher redline of the racecars.
Old 05-08-2014, 09:23 AM
Tilikum Turbo's Avatar
Originally Posted by Ronnie's.930 View Post
No quite - I've never gone this speed in mine, but according to the factory owner's manual, 4th gear on a 1987 930 is good for 167mph. And an additional interesting tidbit in there - they claim it is safe to downshift from 4th to 3rd at 130mph in 4th.
I don't know really what the final-drive ratio is on my 915 tranny, and that may be some of the difference on the top end. Of course, I gained another 500RPMS going to redline from the 3.0SC motor to the 3.3L turbo motor, which pushes the car(with additional stroke of 3.0 versus 3.2 crankshaft) from about 140 original top speed to 155(at redline).
That graph you speak of...is that past red-line where the line simply goes off the chart?
Can anyone provide a picture of their car at max speed in stock 3.3L with regards to the tach showing 6850RPM? or tell us at max RPM, what was indicated on speedo?
I still think my 2850 RPMS at 70MPH(in top gear) for me is too high.
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 05-08-2014, 09:59 AM
I know all of you guys are right about the technical reasons for the 4 speed, but I always assumed philosophically the turbo was usually second priority for development and modernization. The 4 speed in 76 is fine but absurd in a 70k 1988 supercar.
The regular 911 had real efi starting with the 3.2s right. The turbo had CIS injection until 1994. It had been an archaic system for at least a decade by then.
07 Exige S
Old 05-08-2014, 10:47 AM
Banned
In what way is the 4 speed absurd considering that it works so well with the Turbo power plant?
Good point about the continued CIS usage- I've often wondered the same thing.
Old 05-08-2014, 10:54 AM
The 4 speed worked better than a 5 speed would have, The basic nature of the car did not change, so why add an additional gear to make the spec sheet enthusiasts happy? I drove 4 speed 930s for over 25 years, stock and modified, US and ROW, and never once wished for another gear. The high first gear was nice, compared to the uselessly low first gear in a normal 911. 4th gear made for relaxed highway driving and there was enough torque that a downshift was never needed. Why add one more shift from 1st to 4th?
One of my Porsches now has a 6 speed. F'ing irritating, more often than not. It's not like the 6th gear is a real tall one. It's more like an older 5-speed 5th. Just one more shift, every time I run through the gears. It's not like I need the tighter splits for acceleration. It's got plenty of that.
In the early 1990's Porsche was cash-poor. You had a choice of a modified CIS turbo, or no turbo. Which one would you have preferred?
JR
Old 05-08-2014, 11:16 AM
all else being equal 5 speeds are better than 4. There are a lot of ways they could have approached a 5 speed in the 930s that would have been an improvement in my opinion.
A bit lower and closer 1-4 for example and keep the super tall top gear as 5th, would be my preference. everything is a compromise and the 4 speed is fine but it would have been great if it wouldn't have taken until 89 to improve.
My sentiments had nothing to do with the economic realities at Porsche. I'm glad they kept the turbo around, if keeping cis allowed them to do it, fine. It is an older and inferior system to what would have been state of the art at the time however.
07 Exige S
Old 05-08-2014, 11:28 AM
Keep in mind I have owned my 930 for literally more than half my life, and turbo 911s are my favorite material items on the face of the planet. With those qualification, I am not sure the 4 speed does work that well with the 930. Or at least I think a 5 speed with well chosen ratios would be a huge improvement.
My 930 is completely stock and the combination of the super tall 1st and laggy power-plant make it a bit of a dog off the line
07 Exige S
Old 05-08-2014, 11:33 AM
all else being equal 5 speeds are better than 4...
I disagree. Why anybody would want lower gears for first and second is beyond me. A stock 930 couldn't put all of it's power to the ground in first gear anyway, so a lower one would just have made that problem worse. An early one with 225 rear tires, or a modified later car could haze the tires in second when the boost came in, so why use a shorter gear that makes that problem worse? Once rolling, I never used 1st again.
Around town, I could easily skip 3rd. Just run it briefly into the boost in 2nd and drop it into 4th and cruise. I've got decades of seat time in normal 911s too and you'd have to drive the snot out of an SC or Carrera to keep up with a loafing-along 930.
You should have seen the gearing sometimes used in the 935.
JR
Old 05-08-2014, 11:39 AM
If you have an '84, it must be a ROW-spec car. Has it been federalized?
JR
Old 05-08-2014, 11:41 AM
Banned
So true! Not to disparage aschen's opinions on the matter , which he is entitled to, but you often hear people say that a 930 is a dog off the line or when puttering around town, and I always think, "say what"?
I also really like the 4 speed characteristics that you describe - really nice to make so few gear changes, even when just running errands around town, and there is so much engine torque available that even with low RPM all one has to do is press the accelerator down a couple-a-three millimeters and one is suddenly hauling much ass!
Old 05-08-2014, 11:58 AM
JR
Sorta.....maybe
It has a the euro fuel system and exhaust, no air injection or cat. There was some half assed attempt to add a charcoal canister though. So it is basically stock euro power. It made a healthy 265 whp a few years ago.
You guys don't think a 930 is a dog off the line? I thought that is pretty much the defining characteristic of the car. Which car is better an 88 or an 89 930?
07 Exige S
Old 05-08-2014, 12:22 PM
also not trying to be argumentative, but enjoy a bit of discussion.
What would be the finishing order for the following drag race from 0-25mph
1. 88 930
2. 89 930
3. 88 or 89 Carrera
4. 88 or 89 944 turbo (just for fun)
I suspect the results would be the reverse of the order listed, but I could be wrong
07 Exige S
Old 05-08-2014, 12:29 PM
one more supporting piece of evidence for 5 speed superiority
Ruf spent big bux on a 5 speed 930 transmission
it was once a very popular upgrade to put a lower R&P, Ive been told the difference is like adding 100 hp, the problem of course is that 4th becomes a bit short for the freeway (so a higher fifth would be welcome).
07 Exige S
Old 05-08-2014, 12:34 PM
wayner's Avatar
My own opinion relating to this comment is that through today's lens, that comment makes sense but back in the day the idea of more gears was only just starting to catch on as a measure of value.
To that point more gears were more common on less powerful vehicles and was a sign that you had to work the gearbox to keep up with everyone else.
I think the typical consumer view was that bigger motors didn't need as many gears to keep up or get ahead.
Technical reasons aside, marketing in many motorcycle and car companies only started to cash in on the more gears idea mid 80s and later.
Aside from technical reasons, "Lots" of gears really didn't become a mainstream marketing tool for many years after
Old 05-08-2014, 12:37 PM
The loss of the air injection adds a little lag. You may also have non-standard ignition timing, as it's hard to find enough octane to run the thing with stock ROW specs and not have some detonation. At least 93 octane is needed and 94 is better.
Any Porsche is a slug off the line, compared to something like a Corvette. It's all a matter of degree. A 930 would lag a NA 911 for the first couple seconds but by the time the 911 driver was reaching for the shift lever, the 930 would be blasting past and that would be the end of that race.
I don't drive my cars like that, though. I don't care who's first off the line, or 2nd, or 3rd...
I'd pick an '88 930 over an '89 930 every time.
I'd pick an '83-'85 over any of them and ROW over US, every time.
JR
Old 05-08-2014, 12:39 PM
yeah they even had an add or something, that the car was so fast it didnt "need" a 5th gear. I think that is what I would classify as a marketing spin.
I believe the gentleman that said earlier that the racing cars were faster but less durable with 5 speeds was probably correct
07 Exige S
Old 05-08-2014, 12:40 PM
Not that I agree with you but a Ruf BTR drives nothing like a stock 930. Then there's the issue of the extra gear and the problem that creates with a shifter based upon the stock part. One must be real careful in going from 1st to 2nd.
JR
Old 05-08-2014, 12:43 PM
Less durable, yes, but nobody said the 5 speed car was faster. The Carrera turbo (5 speed) was built to a different set of rules than the 934 and 935 (four speeds) so a comparison is impossible.
Porsche chose to use a 4 speed in the 917/30 and they had 5 speed boxes sitting on the shelf.
A 935 will run around 9.0/150 in the quarter mile with a fairly tall set of gears in a 4 speed box.
JR
Old 05-08-2014, 12:47 PM
