Banned
Well said, Dave. I've done a lot of racing in my time, and one of the main goals on track is to shift as little as possible.
Fleabit peanut monkey
I was real scared. Owner and I swapped cars. He smoked me in the twisties driving my 81. He tracks his other Porsche though, so way more skill. You are not officially a numbnutzzz as Ronnie says unless you drive real fast like you have the skill when you don't. But, then, that would be most of us street only guys, even in the NA 911's.
1981 911SC Targa Last edited by Bob Kontak; 05-08-2014 at 09:07 AM.. |
gearhead
Java dog pretty much nails it. The chassis was homologated, so they had to fit the gearbox in that space. It was done on the fly after 915's in the first 930 racecars started failing.
To this day the 930/962 gearsets are the widest gears Porsche ever made. Tallest I have ever seen is a .61. Not that much taller than the stock gear, but talk enough to break 220mph at LeMans with the higher redline of the racecars. |
That graph you speak of...is that past red-line where the line simply goes off the chart? Can anyone provide a picture of their car at max speed in stock 3.3L with regards to the tach showing 6850RPM? or tell us at max RPM, what was indicated on speedo? I still think my 2850 RPMS at 70MPH(in top gear) for me is too high.
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!) 1996 Toyota Corolla(der 'clapper') |
I know all of you guys are right about the technical reasons for the 4 speed, but I always assumed philosophically the turbo was usually second priority for development and modernization. The 4 speed in 76 is fine but absurd in a 70k 1988 supercar.
The regular 911 had real efi starting with the 3.2s right. The turbo had CIS injection until 1994. It had been an archaic system for at least a decade by then.
84 930 07 Exige S |
Banned
Good point about the continued CIS usage- I've often wondered the same thing. |
One of my Porsches now has a 6 speed. F'ing irritating, more often than not. It's not like the 6th gear is a real tall one. It's more like an older 5-speed 5th. Just one more shift, every time I run through the gears. It's not like I need the tighter splits for acceleration. It's got plenty of that. In the early 1990's Porsche was cash-poor. You had a choice of a modified CIS turbo, or no turbo. Which one would you have preferred? JR |
all else being equal 5 speeds are better than 4. There are a lot of ways they could have approached a 5 speed in the 930s that would have been an improvement in my opinion.
A bit lower and closer 1-4 for example and keep the super tall top gear as 5th, would be my preference. everything is a compromise and the 4 speed is fine but it would have been great if it wouldn't have taken until 89 to improve. My sentiments had nothing to do with the economic realities at Porsche. I'm glad they kept the turbo around, if keeping cis allowed them to do it, fine. It is an older and inferior system to what would have been state of the art at the time however.
84 930 07 Exige S |
My 930 is completely stock and the combination of the super tall 1st and laggy power-plant make it a bit of a dog off the line
84 930 07 Exige S |
Around town, I could easily skip 3rd. Just run it briefly into the boost in 2nd and drop it into 4th and cruise. I've got decades of seat time in normal 911s too and you'd have to drive the snot out of an SC or Carrera to keep up with a loafing-along 930. You should have seen the gearing sometimes used in the 935. JR |
Banned
I also really like the 4 speed characteristics that you describe - really nice to make so few gear changes, even when just running errands around town, and there is so much engine torque available that even with low RPM all one has to do is press the accelerator down a couple-a-three millimeters and one is suddenly hauling much ass!
It has a the euro fuel system and exhaust, no air injection or cat. There was some half assed attempt to add a charcoal canister though. So it is basically stock euro power. It made a healthy 265 whp a few years ago. You guys don't think a 930 is a dog off the line? I thought that is pretty much the defining characteristic of the car. Which car is better an 88 or an 89 930?
84 930 07 Exige S |
also not trying to be argumentative, but enjoy a bit of discussion.
What would be the finishing order for the following drag race from 0-25mph 1. 88 930 2. 89 930 3. 88 or 89 Carrera 4. 88 or 89 944 turbo (just for fun) I suspect the results would be the reverse of the order listed, but I could be wrong
84 930 07 Exige S |
one more supporting piece of evidence for 5 speed superiority
Ruf spent big bux on a 5 speed 930 transmission it was once a very popular upgrade to put a lower R&P, Ive been told the difference is like adding 100 hp, the problem of course is that 4th becomes a bit short for the freeway (so a higher fifth would be welcome).
84 930 07 Exige S |
To that point more gears were more common on less powerful vehicles and was a sign that you had to work the gearbox to keep up with everyone else. I think the typical consumer view was that bigger motors didn't need as many gears to keep up or get ahead. Technical reasons aside, marketing in many motorcycle and car companies only started to cash in on the more gears idea mid 80s and later. Aside from technical reasons, "Lots" of gears really didn't become a mainstream marketing tool for many years after Last edited by wayner; 05-08-2014 at 12:40 PM.. |
Any Porsche is a slug off the line, compared to something like a Corvette. It's all a matter of degree. A 930 would lag a NA 911 for the first couple seconds but by the time the 911 driver was reaching for the shift lever, the 930 would be blasting past and that would be the end of that race. I don't drive my cars like that, though. I don't care who's first off the line, or 2nd, or 3rd... I'd pick an '88 930 over an '89 930 every time. I'd pick an '83-'85 over any of them and ROW over US, every time. JR |
yeah they even had an add or something, that the car was so fast it didnt "need" a 5th gear. I think that is what I would classify as a marketing spin.
I believe the gentleman that said earlier that the racing cars were faster but less durable with 5 speeds was probably correct
84 930 07 Exige S |
JR |
Porsche chose to use a 4 speed in the 917/30 and they had 5 speed boxes sitting on the shelf. A 935 will run around 9.0/150 in the quarter mile with a fairly tall set of gears in a 4 speed box. JR |
