Bulb Holders for Turn Indicator in Tach
Does anyone know what the part number is for the bulb holder for 1.2W turn indicator bulbs in the Tach and where I can buy a couple? One of mine from the 78SC disintegrated when I pulled the bulb out of it.
I purchased a set of "bulb holder (dual pole, small bulb)" 999-632-009-10-OEM from our host that I thought were the replacement parts but these are for the 2-4W bayonet type BA7 bulbs I think. Too big for the little indicator bulbs. If anyone has this information I would appreciate it. I need the bulb holders to finish a full LED conversion of external brake, reverse, parking and turn signal lights and internal instrument and indicator lights. Thanks in advnace |
Could really use some info. No one else has had to buy one of these?
Thanks |
I don't have the part number, but I was able to get a part from the dealer that is the supurceded version. It's plastic instead of aluminum, and I had to sand it down a bit to fit. I made the same catalog mistake you did.
Kinsley 1980 SC Targa - MS2, EDIS |
Troll Hunter
I wish they made LED's for these.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
1-6-2-4-3-5-1-6-2-4-3-...
'70 911E Coupe, Webers 40IDA |
Looks like item 11 in the PET. You could try a WTB ad in the Parts Forum.
999 632 007 00, 999 632 009 10, or 999 632 002 00 (82-)
Ed 1973.5 T |
Thanks guys, I will check the dealer to see what they have. NYNick they do make LEDs for replacement. That is what I am going to use.
Thanks |
