LinkBack Thread Tools Rating: Thread Rating: 1 votes, 3.00 average.
tazzieman's Avatar
I currently have a 924 , 944 , 911sc and 928.
Extensive reading leads me to believe they all have extremely strong bottom ends.
There's a common theme there. You tend to hear the word "overengineered" and Porsche quite a lot.
But the usual caveat of proper oils and reasonable change intervals apply. My sc had a PO full rebuild for bad studs and a spun bearing. 1/2 of that was avoidable.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 06-26-2014, 03:11 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
Originally Posted by Wew View Post
Bushings, bolts, nuts, Cleanroom wipes #8nose bearing all on order. Will take apart and look at status of teeth on gears. Spending my money is sweet
1st n 2nd gear are being addressed as well.
I think this is a good move. I did mine this winter after finding a broken head stud. My thinking was that I didn't plan to do this whole engine drop and rebuild thing again, so whatever I might want done in the next 20 years I did, but only if there was an indication of a problem. I only opened up the bottom end because the oil report had some suspicious numbers. I only replaced the cams because there was some pitting and scuffing on some of the lobes (Start with maintenance, end with disaster. Or opportunity)
So I ended up with new suspension bushings, rebuilt rear shocks, lots of powder coated sheet metal, 964 cams, and many niggly things addressed. And many smiles. Go for it!
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 06-26-2014, 01:03 PM
Bill Douglas's Avatar
Originally Posted by Bob Kontak View Post
If you do not address the lower studs, I will kill my cat.
Man, that gave me the serious giggles. I'm pleased I wasn't drinking hot coffee at the time.
Just my opinion. I have no brains of my own I just quote you guys... I would definitely do the cams while it is open. I hadn't heard of this Super SC grind but it sure sounds fun, 20 21 grind or 964.
Old 06-26-2014, 01:53 PM
Packy's Avatar
Originally Posted by rkeele View Post
since you live in Ca. I don't think you can pass smog with cams for the street.
Bob
From what I understand 9.5:1 and 9.8:1 pistons and 964 cams will pass smog in Cali. Don't know this first hand, but this is the direction I'm going to go.
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 06-26-2014, 04:17 PM
Straight shooter
Lapkritis's Avatar
Originally Posted by efhughes3 View Post
I'd simply go with new Viton o-rings and Dow 55.
DC 55 weakens Viton significantly. Go with an inert grease to maintain maximum seal strength.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-26-2014, 04:51 PM
