Dead Porsche needs help!
Hi folks , got a battery warning light and car eventually died. Barely got home. I jump started it and the voltage at the battery end across the wires going to battery is 11.92 volts.
Is a new alternator needed or can it be refurbished? Is this a voltage regulator issue?
Are there any other possible causes?
Thanks a lot
Old 05-13-2014, 12:31 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Thanks a lot
If its running and you got only 11.92, your alternator is not putting out as it should be around 13.8 Volts.
First thing is, what years is the car?
Who Will Live... Will See
Old 05-13-2014, 12:34 PM
ROW '78 911 Targa
timmy2's Avatar
Year of car and remote or internal VR?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-13-2014, 12:46 PM
dead porsche
Sorry lads - car is an 83 SC. I have checked that the fan and pulley are seated properly also and all seems well there.
Also, have had the battery checked out and although it is now low, it is a good battery.
Thanks a lot for the help
Old 05-13-2014, 01:01 PM
Extra info
Also, I should add that when I accelerate or keep the revs up it put the battery light out for a while, then it returned.
Old 05-13-2014, 01:12 PM
put a charge on the battery and see it it will hold the charge.
With the car running your should get 13.5+ voltage. If it is anything under 12.5 you have an alternator problem.
How was the battery tested?
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 05-13-2014, 01:18 PM
charging
Thanks - i connected jump leads and charged battery a bit from another car. Then fired up 911. Started first time, but when I then disconnected jump leads, battery light came on and voltage across battery cables reads 11.92v.
Old 05-13-2014, 01:20 PM
bgyglfr's Avatar
That sounds like charging issue. I had a Carrera that had an issue charging because the dash light was bad. Something about the alternator needing a signal to tell it to charge? Also, make sure all of your grounds are good.
73T
68L
70T 2.7RS spec.
68L coupe
Old 05-13-2014, 01:29 PM
ROW '78 911 Targa
timmy2's Avatar
Alt light is working normally as it turns on.
First have the battery tested for failure.
If good, then the alternator is the suspect.
Dennis
Old 05-13-2014, 01:35 PM
battery
Thanks - well I had the battery tested at the store i bought it from and they said it was good but i'd drained it a bit. It's a new battery.
Old 05-13-2014, 01:38 PM
tharbert's Avatar
To answer your question, yes, they can be rebuilt if you have a shop around your area that still does that type of work. Seems it's a dying art, rebuilding alternators, starters and generators.
Edit - Hmmm: FS: Slightly Used Voltage Regulator
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 05-13-2014, 01:59 PM
Charge the battery.......
Put the battery under charged over-night. Check the battery voltage and try it again. Take another voltage reading with the engine at idle. See what you got.
Tony
Old 05-13-2014, 02:01 PM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Curious if you experienced any strange behavior with your tachometer? My alternator went in my '83 SC and the tach was acting very strangely - the needle was bouncing erratically. Tried to get it rebuilt and was told it was not rebuildable - cannot recall why. Replaced the alternator and have not had a problem since.
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 05-13-2014, 02:28 PM
Welcome to the slippery slope.... sounds like an alternator but while you are at it ... how about powder coating the shroud and fan
What I should of done when I replaced mine.
Old 05-13-2014, 02:42 PM
Thanks - just wondering is there any way an earth issue would give me a low reading on battery?
Also I can see an alternator for sale for a 911 Turbo . It's a Lucas . Will that work on an sc if the year is the same ?
Old 05-14-2014, 12:08 AM
JJ 911SC's Avatar
More then likely not.
Once you determine what is wrong, here are the parts for an 83.
Voltage Regulator:
1983 Porsche 911 SC Coupe - Charging System & Battery - Page 1
New alternator (cheaper than the Bosh rebuild):
Rebuild alternator (with core charge):
Old 05-14-2014, 02:52 AM
Top man thank you
Old 05-14-2014, 10:00 AM
