torsion bars for my 73 targa?
I have a 73 targa with a 3.2l motor, koni adjustable struts in the front and bilstein hd's in the rear. I am most likely going to install some polybronze bushings all the way around and I need a rear sway bar.
I was going to run a set of turbo Tb's(I already have a set laying around) on the rear and 21 or 22mm Tb's in the front. I can run a set of adjustable koni's in the rear of custom valve shocks.
This car will see spirited road driving and possibly a DE.
Thoughts or suggestions
I do have some alum rear control arms that I could put on. What is involved with that?
Currently there are 16" Fuchs but I plan on running 15" 6/8's.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 05-26-2014, 09:23 AM
rkeele's Avatar
yes install alum. swing arms they will bolt right on to a 73 much lighter, if you install larger front torsion bars you'll need rear ones they are more important anyway.
Old 05-26-2014, 09:42 AM
Max Sluiter
Flieger's Avatar
21 or 22 is going to make the car very front stiff. I would not use 22mm fronts without at least 29mm in the rear. Turbo 19/26 should be a good place to start.
Old 05-26-2014, 10:15 AM
HarryD's Avatar
I put 21/26 t-bars in my 1973 to reduce squat and a tire rub. The ride is still very acceptable on the street and is noticeably better at Autocross.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-26-2014, 10:19 AM
John,
I just bumped up to 22/28 from 21/27 and I'm okay with the 'firm' ride. It's not too harsh.
I also switched to alum trailing arms this year - you'll probably need the hubs that go along with it. I think the bearings, etc are larger that leads to a beefier hub. Also may need the plates for the e-brake. If you have an early '73, you may have to drop the engine to get the front bolts out - I think they changed mid-year with the notch in the tb tube to allow easier change/repairs. (I, of course, have an early). And, you'll need slightly longer eccentrics for the thicker alum arm. If yours is an early, Wevo has a special replacement bolt that allows changes/bushing replacement without dropping the engine in the future.
good luck,
kj
Old 05-26-2014, 08:53 PM
safe's Avatar
I would stay with 19 if you have 26 in the rear. I have 21/27 and would not recommend anything with more front bias.
Magnus
Old 05-27-2014, 04:39 AM
Thanks guys.
From a cost stand point I plan on staying with the turbo tb's in the rear. I may have the turbo tb's for the fronts. I will have to look. IIRC they should be 18.8mm. I would guess that should be close enough.
Next would be is it worth it to switch to alum trailing arms. I have a complete set that I pulled from an 84 targa, parking brakes and all. I don't know if I have an early or late 73. Are there any modifications that need to happen with the axles? The trailing arms I have have the stub axle in them. I guess another incentive is I will not need to buy a sway bar as I have a couple rear sway bars from later cars and currently my 73 doesn't have one.
Old 05-27-2014, 04:55 AM
I have 21's & 26's in my 2190 lb hotrod and find the ride perfectly acceptable and the handling great. It is not good on very poor road surfaces but I try to avoid those. While you are in there, be sure to reinforce the rear sway bar mounts to save yourself headaches down the road.
regards,
Phil
Old 05-27-2014, 09:32 AM
tctnd,
I will do. It is on the list. I think I will do the rear suspension first and the front after, to keep the down time minimal.
Old 05-27-2014, 09:54 AM
HarryD's Avatar
Originally Posted by sundevil64 View Post
tctnd,
Each time you mess with your suspension, you will need to repeat the alignment and corner balance. This is a significant cost. As recommended to me by Steve Weiner (Rennsport Systems), to save your money, do all the changes and then tune your suspension once. It will take about a day or two to do the total job.
FWIW, I had Jeff at Rothsport Road and Race do the suspension tuning after I installed the parts. I asked him about setting the ride height prior to having him align and corner balance. He told me if I wanted to practice doing this job, it was fine but it was likely he would still need to make adjustments and there would be no cost savings. I let him do all of the adjustments.
Harry
2020 MB E350 4Matic
Old 05-27-2014, 06:51 PM
Non Compos Mentis
I used 23mm front and 31mm rears in my 3.2 powered '73 coupe.
To do over, I'd do..... exactly the same!
The car was primarily an Autocrosser. Some may find it a bit stiff for a daily driver, but I love it that way.
Old 05-27-2014, 09:05 PM
safe's Avatar
Originally Posted by harryd View Post
to save your money, do all the changes then and tune your suspension once.
+1
Magnus
Old 05-27-2014, 11:43 PM
