vansicklenmi's Avatar
H1 trim ring/ adjustments screws?
One of the long trim ring/ adjustment screws on one of my H1 is bent and needs replacement. How do you remove them from the trim ring?
'75 Carrera, It's stock, I swear, scouts honor!
Old 06-13-2016, 07:40 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It is held on by a thin nut, hold with pliers and remove it.
Post a pic to insure it is not supposed to be that way.
'85 Carrera Targa
PCA/POC
Old 06-14-2016, 12:40 AM
The screw has a metal "bead type" device crimped to it. Contact Jaudette3 on the forum. He rebuilds H1/H4 headlights and could help you with a new screw. He also has a solution that he uses to replace the "crimped on" piece for the rebuilds he does. He's a very helpful guy!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 06-14-2016, 06:50 AM
DRACO A5OG's Avatar
That's right a bead type, but it is threaded too. So you can hold it with the pliers to remove the screw.
'85 Carrera Targa
PCA/POC
Old 06-14-2016, 08:22 AM
If you can straiten the screw shaft, perhaps check your local hardware store for a Nylock
type nut to fit the screw as you will most likely ruin the crimped part while removing it.
Old 06-14-2016, 08:43 AM
